Sake Bomb FP Spec Sway Bar Rates?
Anyone know what the rates are on the Sake Bomb's FP Spec Sway bars are?
Product link below: https://www.sakebombgarage.com/fpspe...sway-bar-32mm/ |
I've read before that there is no standard way to measure swaybar rates. Therefore, there is not necessarily an apples to apples comparison between published rates unless they are done in the same way, likely at the same time. I'm not sure if the absence of numbers is for that reason or not.
I'm going to assume that it is similar to dyno numbers that raw numbers don't tell the whole story but may be enough to draw some kind of conclusion. i.e., if the difference between published rates is significant, you can draw some logical conclusions. I'd be curious what the range of the bar is as well within the adjustment range. On my stock 06 and previous 03, each with just tires (245/255 and 225/225), the balance of the car can be significantly changed just from adjusting the Karcepts bar. With just that, I've been able to adjust it from an understeering mess to very loose. Hopefully this bar is stiff enough and has enough adjustment range to be a viable option for those who do not want to spring for the Karcepts bar. |
I'd really like to know how it compares to this:
https://www.s2ki.com/forums/s2000-br...prings-818884/ I have a CR bar and want stiffer, but would like to know how much stiffer i'm getting relative to this. |
