saner or cr?
saner or cr?
I already searched and checked out the official sway bar thread. I'm still having a hard time deciding between the adjustable saner front sway bar or a cr. My car is pretty much stock ap2 and I only use it as a dd or for the occasiaonal mtn runs. I just want to tune out some body roll and add some understeer. I'm afraid the cr bar might be too soft and the saner bar too stiff for my stock setup. Anyone running a saner bar on a stock ap2 care to share their thoughts?
I had the saner bar on full soft when I had 225/255 star specs on the car with stock suspension. Made a good difference in handling. Car had more low speed push in tight autox's but made the car more stable in higher speed sections
If you don't add more front tire, but add more front roll resistance, you will have more understeer, especially in the lower speeds, like slowd16 experienced. If you want less body roll, get stiffer front and rear springs, or stiffer front and rear roll bars. BUT, beware of unintended consequences of modification for the sake of a want or a feeling of need.
you might find an 00-01 bar cheaper its reported to be about the same stiffness as a CR bar maybe stiffer
it sharpens up the car a bit but I don't think it will be enough to change the balance
the saner on soft should definitely dial in understeer but it might be too much,
I think it is 100% stiffer than stock 00-01 bar on soft and 250% on stiff, whiteline is about 50% stiffer
the info is on s2ki somewhere if you can find it
Ive had the front comptech 32mm and it's just not enough. I initially thought it would be good enough since I only dd, but because the saner is adjustable I can tailer the bar to my specific needs at different times.
It's worth the extra money.
shadowz64
02-20-2023 03:00 PM
