Smallest wheels that fit over s2k suspension? (not brakes!)
I searched and couldn't find the answer so I'm hoping one of you gentlemen might know. In order to understand why I ask the question, this is for a locost project (you know, like a Lotus 7?) that will be considerably smaller and lighter than an s2k. I want to use s2k suspension because I really like the design, but in order to keep the unsprung weight down I would like to use smaller than oem wheels and brakes (because on a light lower-powered car smaller wheels/tires = faster), soooo... ignoring the brake rotors and calipers, what is the smallest diameter wheel that will fit over an s2k's front and rear suspension? Thank you for any and all help!
C'mon guys, 100+ views and no responses? Surely someone out there must have some idea about this.
How about if I ask the question in a simpler way: How close is the nearest suspension component to the wheel, and what diameter/width/offset is the wheel? |
If you want to use custom brake rotors, calipers, knuckles, etc. it will depend on the wheel offset. A 17x9 +63 pretty much hits the A-Arm at full lock on front.
If you spec out a custom brake kit with calipers and rotors in say a 260mm size, and keep the upright, maybe you could get a 15 inch wheel on there? Plenty of performance tires available in that size. |
Originally Posted by silhouette
(Post 24494205)
Pretty sure you can fit the right 15" wheels even over the stock brakes.
Still not clear what you're really trying to do here. You're going with a different chassis, but want to replace that suspension with the full S2K suspension? Then you'd need to re-create the S2K control arms' mounting/pickup points on the new chassis, correct? But those points are based on the S2K hub, which is sized to carry S2K rotors & calipers...?
Whatevs. :) Here are a couple schematics of the AP1 suspension. Rims shown are the 16" AP1, so you can scale from there. https://cimg3.ibsrv.net/gimg/www.s2k...5f89f773f1.jpg https://cimg5.ibsrv.net/gimg/www.s2k...c1b0114adf.jpg |
Its a lowcost 7, so the frame is custom. He is either fabbing it up himself, or buying one from a vendor. Its so low volume that he could likely order the frame sans suspension mounts, and add those himself.
Those photos from 2whose (sorry, couldn't resist playing on the name) should get you pretty close to an answer, since the wheels are to scale. |
