Speed Academy S2000 Track Alignment Specs
Here's a link to their site and the subject.
Note they repeat what I've stressed about suspensions when guys want to "upgrade" to adjustable coil-overs, that the settings are not magic and dependent on which specific track you're running, what tires, the driver (!), etc., etc. And they make adjustments all the time. Still good information though.
-- Chuck
-- Chuck
The infamous UK 1/4" (~0.6°) total rear toe spec strikes again... I tried it years ago, and found it to suck, bad, for everything (handling predictability/linearity, tire life, stability in a straight line, tire life, responsiveness at turn-in, tire life, etc..).
Way way too much rear toe IMO, I like about 1/4 to 1/3 of that, 0.15° to 0.2° total rear toe in.
I have found 0.28* total toe works best for me. I would definitely suggest they swap their camber settings front to back (at minimum) since they are running square if I recall correctly.
I do... I'm 3.75* front, 3.25* rear, 7* caster, 0 toe front, .20" total rear toe
My tire wear is even across the tire.
As always, you can't look at one area of the car, you need to look at the whole setup -- the car, the driver, and the track.
brent_strong
06-29-2009 01:04 PM
