Spoon calipers vs. Stoptech BBK
#22
Originally Posted by Lakersfan,Oct 30 2010, 04:29 PM
Lot's of misinformation on this thread........
I own spoon calipers
They stop the same as oem but oem does feel better
No bbk stops better than oem, sometimes worse because the pads people use are designed to be useful at higher temps and bigger calipers require more fluid to move the pistons vs the single sliding caliper that is stock.
If I was spending my money again I would have bought alot of other things before the calipers but they look great so I'm keeping them
#23
ABS uses a sensor that reads the notches off of the hub (there are 50). Any caliper/rotor combination you put on will still allow the ABS system to still read from the wheel sensor.
#24
You are correct and that is just one piece of misinformation in this thread. Stoptech BBK's have no impact on the ABS system of any car because no changes to the sensors or ABS hydraulics are made. ABS measures wheel speed/lock up via sensors on the hub (in Honda's case). The sensors are not on the rotors or calipers. Any reputable manufacturer of BBK's (like Stoptech) has white papers, etc. on their sites to explain how such systems will impact the friction system of a car.
#25
http://www.stoptech.com/tech_info/wp...rakekits.shtml
per the article, stoptech's system is compatible with abs due to the overall balance and design, including calipers and rotors, not because abs sensors and hydraulics remain unchanged.
#26
You are correct. Here's another link to a summary of individual reference documents:
http://www.stoptech.com/tech_info/faqs.shtml#17
http://stoptech.com/proven_technology/test_wins.shtml
BTW - I have a few friends that work for the company (full disclosure) so, as you can imagine, discussions about friction come up all of the time . That said, I'm no expert - just an informed novice.
I'm not knocking other brands but how many company CEOS's are professional race car drivers and use their own products on the track? Take a look at their web site and you will see. The leadership team of this company are all passionate car guys. They not only work hard, they play hard.
#27
#28
Also many people seems to want BBK for the wrong reasons. BBK's won't necessary stop any shorter than OEM. But the main reason for any BBK is for consistency. Same braking distance over and over, same brake feel over and over is what BBK can provide over OEM.
In fact, if anyone wants shorter stopping distance only, don't bother with BBK, but get better tires. Tires is what will allow you to have a shorter braking distance, not calipers and rotors.
#29
Agree on buying BBK's for the wrong reason. One could argue that I bought an S2K for the wrong reason as I have no intention to track or autocross it.
As for for my reference to the CEO be a professional racer, I just stated a fact and I will take your word on the Spoon CEO. From what I know, Spoon makes all sorts of aftermarket parts whereas Stoptech's primary focus is on friction. The parent company is a friction company. I know that this started out as Sppon vs. Stoptech but can you argue that they are comparable (i.e, Spoon makes a BBK?). Doesn't Spoon make upgrade components for the S2K vs. a true BBK?
Anyway, I just wanted to make sure that some of the misinformation regarding ABS and non-balanced systems was corrected. I have nothing to gain either way.
#30
