Stoptech Rear BBK Megan Toe Arm Clearance Issue
I've been running a Megan rear toe arms on an AP1 track only. Went to install a set of Stoptech rear BBK but the rotor won't clear the rod end of the toe arm. Has anyone run across this issue? Any solutions? Anyone running different quality toe arms with the Stoptech BBK? Only solutions I can think of is: 1) source another thinner or different designed pillow ball bushing (PIA) or 2) buy another set of toe arms - but don't want to risk having the same problem 3) go back to OEM but that would be a very last resort. HELP
how much clearance are you short by? you could always run a thin (~1-2mm) spacer between the rotor and hub and shim the caliper bracket out accordingly. you can get thin spacers like that really cheap on fleebay. You dont want to run more than like 2mm though as you will loose to much thread engagement on your lugs
if its really not clearing by that much you probably have a bigger issue. I wouldn't think that the stoptech rotor would move inboard by that much. You wouldn't need to mill the caliper though as you are moving it further away from the knuckle so you could simply shim it outboard more.
Gregrocks you're exactly right!!! I received 3mm and 5mm spacers yesterday and took a few minutes to test fit them last night. Think I can get by with the 3mm plus a slight 1mm grind of the face of the spherical bearing closest to the rotor. I looked at the caliper and saw how i could mill the 3mm from the stoptech supplied bracket to center the rotor. Thanks GR for the input, you nailed it.
Moddiction
05-12-2017 08:17 AM
J_D
11-15-2008 08:56 AM
