Sponsored by: Sake Bomb
STR Camber F/R Bias
Old 03-28-2018, 03:46 AM
igorien2k's Avatar
Default STR Camber F/R Bias
I've been reading through the STR setup thread, and I noticed that there tends to be a wide range of suggested rear camber settings, while for the front the general consensus is more is better:
https://www.s2ki.com/forums/s2000-ra...gnment-904840/
I'm guessing that this is likely due to different spring rates, shock settings, swaybars and preferred driving styles. Could someone chime in on what effect the rear camber and F/R camber bias has on the handling feel?
The goal here for me is not outright mid-corner grip, but a setup that will tolerant of my mistakes and allow me to trailbrake / lift to get the car to rotate and then plant the back end via throttle input without causing a spin.
I could try a range of different settings but I'd hate to keep going back for alignments so I'd like to get suggestions for a baseline.
Old 03-28-2018, 05:03 AM
ZDan's Avatar
-3 front, -2.5 rear should be a good enough baseline to start from...
zeroptzero
03-27-2016 07:15 PM
unclefester
10-31-2010 08:27 AM
r8byb
03-17-2009 11:00 AM
Quick Reply: STR Camber F/R Bias
