Sponsored by: Sake Bomb
Super dirty inner brake caliper
Old 02-15-2019, 05:30 AM
minubaba's Avatar
Default Super dirty inner brake caliper
Hi - was doing a brake job and found the inside of the cailiper in this state. Should I assume the piston and seals need replacement?
Old 02-15-2019, 06:24 AM
512S2k's Avatar
The general consensus seems to be to buy a reman and don’t fiddle with trying to rebuild the caliper. How does the other side look in comparison?
There was a guy selling good condition used ones in classifieds btw.
Good luck!
Old 02-15-2019, 06:31 AM
minubaba's Avatar
Okay... I will check other side on Monday. Ran out of time yesterday.
Old 02-15-2019, 09:18 AM
thomsbrain's Avatar
If you clean it with a brush and brake cleaner prior to retracting the caliper, it might be fine as-is.
Old 02-17-2019, 01:43 PM
minubaba's Avatar
The other side very clean.... BUT the piston was seized... I pished the psiton out and it was very badly scored and has zero lube....
just ordered a set for reman nissen rears from amazon. Just 150? Lets see how they work out. Will likely replace both sides.
any tips on releasing and re-engaging the handbrake cable?
Old 02-21-2019, 06:05 AM
minubaba's Avatar
Got the amazon replacements... not nissen but for $147 for two, that is okay i guess.
see my review and link to product:
https://www.amazon.com/dp/B019NUFVR4?ref=cm_sw_em_r_rw_mw_MZDO0jfuafDsN
Fahad93
03-31-2019 08:18 AM
CoralDoc
08-12-2010 04:47 PM
Hollywood Wheels
08-06-2009 01:47 AM
Quick Reply: Super dirty inner brake caliper
