Suspension bushing issue.
Will a torn rear upper control arm bushing cause the alignment to change if the car is driven hard? After a recent autocross, I noticed my steering wheel was off 15 degrees to the right. After inspecting all my suspension parts I noticed my passenger side rear upper control arm bushings were torn/ripped, everything else is in good shape. I'm guessing this is the culprit?
Luckily Honda sells replacement bushings for the RUCA and will be replacing them soon.
After replacing both toe arms and tie rod ends along with the bushings all is well, now to replace the diff mounts.
Yeah I already learned the hard way. I just drop the control arms onto jack stands from a lift then tighten everything.
thomsbrain
05-11-2015 09:21 AM
Chops@MVP
72
03-01-2015 11:39 AM
farzam
08-05-2011 02:24 PM
