suspension questions oversteer
hi guys, would like some input for my new setup.
for 2012 Ill be running 17x10 with 235/40/17 R1R up front
and 18x10.5Nt03 with a 245/40/18 direzza z1
the car is a 04 so ap2, running Bc BR coilovers, spc rear camber bolt
Car is daily driven in the city but mostly out of town in the twisties, Im planning on going to a track day or 2 this summer
But im looking for a set up who will mostly oversteer but would be predictable, since i really like drifting
i had some shitty front tires (215/35/18) last year and was suffering from really bad understeer the reason why i went with a meaty 17 tires up front for 2012...
Most drift car run more camber up front then the rear.
I will get an alignment as soon the ride height is dial in
i was thinking about running -3 all around or maybe -3.5 front and -2.50 rear
what you think ?
what about the running the coil at the stiffest setting in front and a bit softer in the back,
what about sway bars, is ap1 sway bar or no rear sway bar would help for what i wanna do ?
thanks in advance...
what you think ?
lol i still want to car to be drivable, Im not an expert in setting but know what you just said will make the car handle like a old mustang lol its not what im looking for...
What he said. There are too many ways to attack this to get into. How an auto-x wants oversteer vs a road racer vs (not really sure how to define you). Sign up for lapping, learn the car. Adjust based on your budget and needs. You may find a simple toe adjustment can do the job.
Surprised you are running a 10" wheel in front as a DD and not rubbing the LCA
Generally speaking for good handling you set front cambers higher than rears.
for drift it's even more true.
tires wise i think you're at reasobale shape already for street drift.
but if you're in love with drifting - you've picked a wrong car.
you should be looking at BMW's or Silvia's
ill be running 17x10+18 so i should not have any issue rubbing on the lca
so far with all the info ive read and my personal experiences,
im thinking about starting with max out front camber,-2.5 rear,
rear coil on stiffest setting, front half way (16 clicks)
0 toe rear,1/8 toe out front
wont touch the sway bar..
Ill try that and make adjustment front there !
hopefully it should still handle pretty good, and be easy to control sideways...
venague
12-01-2008 03:00 PM
P-CarDriver
03-22-2008 05:29 PM
