sway bar choise ap2 rear
If you want to soften the rear with the ability to dial in the stiffness to your liking, the Karcepts rear bar can go almost as stiff as the AP2 OEM rear and softer than the NC Miata bar.
Former Sponsor
The 00-01 bar is the biggest OEM bar offered. An Eibach bar offers even more bar than that.
Before you get into buying a bunch of new parts though, have you checked your alignment?
+1 on alignment first.
Next, make sure the po didn't accidentally put springs in the wrong end, fronts in the rear, rears in the front. That would totally mess up the balance.
See if you can read the Tien part numbers off the sides of the springs. Then google to see which end should be which.
Also heard of someone that got a car with aftermarket springs installed wrong left vs right! One side was correct, other side had front and rear swapped. Yeah, weird handling for sure. So check all 4.
