Sway Bar End Links
Sway Bar End Links
Hi, I have to replace my front oem sway bar end links. Has anybody used the Hardrace end links?
Also, does anybody have recommendations for good adjustable front end links?
Thanks for any help
Thanks for any help
I figure if I have to replace them, I may as well get ones that will allow me to remove preload from the swaybar. I track my car so I try to make it feel as good as possible and handle well.
You can buy the Hardrace front or rear links for about $50 shipped each.They also sell a rear adjustable link that is 81-91mm for about $65(contact buyhardrace for purchasing). Whiteline makes adjustable ones for front or rear. Someone on S2KI sells front and rear adjustable links on eBay.
I went with Hardrace front and rear links because of the price and rubber bushings to reduce noise. I have a set Hardrace adjustable 81-91mm, but I don't know if they will be used.
More information: https://www.s2ki.com/forums/s2000-mo...s2000-1170700/
Anorexicpoodle on the forum sells adjustable f/r adjustable end links. Ive got both and his customer service when I broke one due to a sway bar mount malfunction was stellar. Id definitely recommend him.
