cooked rear brakes
cooked rear brakes
On a sunny sunday drive today I made the mistake of letting my buddy switch cars with my for a short 2 mile or so stint. He is a miata driver so... he left the handbrake on and didn't notice. We come to a stop and there is smoke coming off both rear brake pads and a the smell of cooked brakes.
I'm pretty sure those pads are toast, which is really shitty as they were almost new Ferrodo DS2500's, most likely as are the rotors. Guess I'm just looking for someone to confirm that, once they have been overheated are the pads gonna be garbage at my next track event? Or could the overheated part of the pad wear off with time?
Regardless I'm making him pay for some of this, and never letting anyone else drive my car... ever
Take them out and have a look,they may be ok will be noticeable on removal how cooked they are/are not.
Definitely do a visual inspection after removing the rear pads and rotors. Should you need replacements, let us know. We sell various performance brake options including Stoptech:
http://store.excelerateperformance.c...s/p-10028.aspx
The above illustration is not correct for any year S2000.
All S2000s have the parking brake as part of the caliper. The brake pads are used to set the parking brake.
Depending on how hot it actually got, you may want to look at all the rubber bits on the caliper. Seals, boots, etc.
I think everything should be fine. One thing to consider is what you did after you noticed this. The rotors could have warped if all you did was park up, pull the ebrake back up and let it all cool off. If you drove off afterwards and let the breaks cool properly everything should be good.
When I first started tracking my S with oem pads, smoke from the rear brakes was pretty much standard issue. lol
One of the warmest days my whole rear calipers turned white and they were originally painted black with proper caliper paint.
I'd take them out and have a lookieloo. Look for cracks in the rotors and anything else thats obviously wrong. The pads might look "glazed" but that shouldnt be a huge deal imo as it'll wear off.
If you dont see anything cracked, warped or completely worn down then I'd run them and dont think about it until its time for new ones.
motocrossmann
09-09-2008 10:54 AM
Zanardi50
03-26-2004 09:07 PM
