What are the best bushings to replace to improve ride quality?
#21
I've actually been considering going with poly for the rear bushings just to keep costs down. Did you notice any extra noise or vibration? That's what I'm mainly concerned about.
#22
I replaced all of my bushings with energy. I noticed a firemen ride wthat is more forgiving. If that makes since. It just seems like the car is sharper. I love it. Get the black bushings, they are a bit better as they have an additive the red ones don't.
#23
Pillow ball bushings don't offer any deflection. They are great for performance, and will totally un-bind the suspension. But in most positions, they will transfer a lot of noise and vibration. They are also more failure prone/maintenance heavy items as compared to rubber. There's a reason manufacturers almost always use rubber for bushings. You should clock all the bushings for their new ride height. They are clocked to stock height when the car leaves the factory. If you lower or raise the car...the bushings need to be clocked to their new position. Inspect your bushings. Replace the ones that are worn/torn. Your clunking could just be loose sway bar links or other suspension hard-parts (ball joints, tie rods, etc).
Basically, they are a low cost solution that doesn't bitch.
If you do any performance driving at all the minimum I would go with is the powerflex monoball
Eric .. do whats right... Vance harnesses
#24
Hey OP, how many bushings did you decide to replace?
i looked at an s2000 bushing diagram and it looks like it has a total of 16! O_O
my 02" s2k has over 160,000 miles too, I'm the 3rd owner.
1st owner lived in California, 2nd owner was a friend of mine, and its never been driven in snow.
i was reading the thread about ES bushings (in this thread: https://www.s2ki.com/s2000/topic/102...w/page__st__50) but they look like a pain in the ass to install (you have to to re-use old rings and torch. laborious & messy).
People linked and also mentioned the Powerflex bushings (poly with imbued graphite) so i was thinking of replacing every bushing with those.
So, how many did you end up doing?
and which did you choose to install?
do you think my idea to replace all bushings is overkill?
also, what the hell does it mean to "clock" the bushing?
#25
Clock the bushing means you jack an arm up to ride height, and tighten the bushing. If you tighten the bushing with the arm in full droop. When you put the car at normal ride height it will stress the bushings and tear them. Not a problem with spherical bushings, only with rubber/poly or material with built in 'give'
Only fix what's broken. If the bushings aren't torn leave them be.
#26
Worked on my friend's STi and most of his factory bushings are booted spherical with some sort of polymer liner bearing. I really dig it.
ES or any bushing that has just plastic donuts to replace the stock rubber bushings will not last very long.
Whiteline bushings seem well made...though, I'm still not convinced they will last a long time in a LCA position (maybe I'm wrong).
#27
Nobody actually mentioned this in any instructional videos or install manuals either.
Seems you guys are a bit smarter than the average bear
Krazykoreankid
08-05-2016 02:37 PM
