Wheel bearings & Suspension Bushings
#21
If I were you I'd just replace with stock bushings. Hard rubber increases bind and you're screwing with the effective spring rate and reducing suspension compliance in the wrong way. Yes, you're decreasing alignment deflection under load, but at a cost to responsiveness to bumps. I say either stock or spherical if you really think you need to control your alignment more under load because you're using R-comps on track or the car is 90% track.
#22
I can understand why they ride super smooth on good roads since the suspension is let to do what its supposed to. How are the rattling attributes over freeway ridges, potholes, and cracked pavements? I know that sharp impacts like freeway reflectors have a sharp clink, but im more concerned with chassis vibration/noise/rattle.
Also if you have even ridden in or know about the ballade set, I am curious how it compares to the Blacktrax/kingpin
#23
Check out the thread on sphericals. Lots of positive comments on ride quality. The only negatives aside from cost is longevity. Maybe not the choice for a 3 season commuter, but otherwise a fine choice.
How much stiffer really are these aftermarket rubber bushings than stock? Because of the small range of motion of our suspensions, I don't think stiffer rubber is going to have that much impact. Plus I imagine the rubbers spring effect is so much less than the springs themselves, that, say, doubling the rubber spring effect will have minimal impact on overall stiffness.
I say go aftermarket rubber.
#24
So, I found a picture with my passenger side lower shock bushing in it, to get an idea of the bushing wear/tear
(from when the suspension was getting worked on for the Ohlins and roll center adjusters)
zoomed in:
The crack looks bad to me since it goes almost to the arm and the center ring especially since it is not under load in this picture either.
Thoughts?
I'll see if I have time to raise the car this weekend to get more pics
zoomed in:
Thoughts?
#25
Mugen vs Spoon
Do Mugen and Spoon use the exact same rubber hardness? I want to know if spoon is harsher than mugen. I see posts that claim Mugen looks just like OEM, the molds, stampings, and all, so it seems like either spoon is harsher, or they are the same.
Also, I see that the Rear Upper Control Arms are different on AP1s and AP2s.
Spoon:
I have found full sets of Spoon bushings AP1 and AP2 that address the difference.
Mugen:
I have found only the AP1 set of Mugen UCA bushings (rear & front are the same on AP1s)
Mugen Part Number: 51455-XGS-S0N0
Does a Mugen set of Rear UCA bushings exist for the AP2 chassis? Because the mugen ones are cheaper most places
Spoon:
Mugen:
#26
I'm in the same boat as you. Just bought a 2004 with 150k. Every mount so far I have taken off has been completely cracked thru (motor,trans,diff). This week I'm going to replace the axels and wheel bearings/hubs, then I was going to drive it a little before I did all the bushings. I'm leaning twords HR
blacks2k
34
09-24-2007 09:24 PM
