Who do you recommend for brake lines?
The install for the Challenge lines was incredibly simple. My mechanic did the first one and I watched, and then I did the last 3. First time I have ever worked on my own car, well the brake system at least. Was much more simple than I thought. The install was also made easy by using the same mounting points as the OEM lines.
Thanks for the insight... I have 300 miles on my car so I'm thinking that the lines and everything should be fairly easy to take off... Just need to do the brake fluid right after that..
Originally Posted by TrackStar,Mar 8 2010, 02:51 PM
What did you go with?
Would you guys recommend I replace the brake fluid with a higher grade? I will not be tracking the car. I think regular brake fluid is sufficient.
Off-the-shelf DOT3 is going to be fine on the street.
Or off-the-shelf DOT4 if you feel the need.
FWIW, I've gotten as good or even better performance out of off-the-shelf DOT4 (castrol, Pennzoil) than out of ATE SuperBlue, which I used once and was quite disappointed with...
