17x9 +60 w/ 255s Squared - Will it rub?
Is anyone running 17x9 +60ish with 255 rubber all around on stock CR suspension without rolling their fenders?
I picked up some Enkei PF01Rs and have 255 Star Specs on them, I'm planning on running the stock CR suspension with a really large front sway and some STR-legal camber adjusters in the front (Hardrace/J's S1). Will I have to roll my fenders at stock ride height with this setup? I'll likely be running -2 or so camber in the front but it's AutoX so I'll likely hit full lock at times and experience lots of compression.
I just don't wanna mess up my fenders but I'd prefer not to roll them unless I really have to.
Thanks!
Thanks!
You may need a roll, but definitely not a flare.
Why only -2 camber if you're going to run a offset ball joint in the front? I also recommend you go straight to the S2.
17x9 +60 will rub the fender tabs. Push those tabs up to clear. 17x9 +63 with ~2.7+ front camber will rub off fender tabs. That is the safest offset of them all though.
I have those exact wheels. pf01's though not a CR. im also running 255's starspecs. I rubbed when I was stock at the track and I still rub once lowered on coilovers with -2 camber. So I would def roll your fenders. Im planning on a roll soon.
Originally Posted by nos4you' timestamp='1331348608' post='21495329
[quote name='takchi' timestamp='1331277932' post='21492444']
+60 should not rub the rear though. It will rub the front fender tabs. Push those in and you're golden.
[/quote]
Ohhhhhh yeaaaa even with plenty of camber
I just bought a set of TSW nurburgring 17x9 +63 and was planning to buy some star specs and go 255 all around; My car is completely stock. I have read that this is what a lot of auto-x guys are doing, does this mean they have all rolled the fenders?
What about 245 instead of 255?
