S2000 CR Club Racer Edition CR stands for "club racer," conjuring up the good old days when guys drove their sports cars to the track, raced them, and then, if the racing gods were smiling, drove them home again
255's
Old 06-06-2012, 12:58 PM
needanotherS2K's Avatar
Default 255's
Hey guys,
Any you running 255's on all 4 corners with your stock CR wheels? Curious if I can make em work on the front.
Thanks!
Old 06-06-2012, 01:05 PM
EVLS2K's Avatar
I think minimum is 8.5 rim width for 255 , the front cr i think are 7.5
If i am wrong please correct me
Old 06-06-2012, 01:06 PM
nlink720's Avatar
I did it for two events last year. It's ok for autocross, but u have to raise front psi by 10 ( I ran 45/35) to keep the proper balance or it will be crazy loose in balance.
Old 06-06-2012, 01:31 PM
skibbz's Avatar
It varies by tire... Star Specs in that size recommend a minimum rim width of 8" but people don't always follow the manufacturer's guidelines.
A lot of people modify a pair of OEM rear wheels so that they can use them up front if they want to run wider tires on the cheap.
Old 06-07-2012, 10:27 AM
DrPcmd's Avatar
Daily drive on 17x7 +49 front 17x8.5 +59 OZ alleggeritas with 255/40/17 RS3s, no rubbing, no funny noises, and the car handles great.
Old 06-07-2012, 03:11 PM
Cool! So I should b fine with adding 255's on the front to help my times on the track. I'm running in rtr and sick of being beaten in pax by a mustang! . I have no prob beating him raw time, but pax in rtr is a diff story. I need to make up half a second on my current times. I'm thinkin 255's at all four corners and a gendron front sway should take care of it.
Old 06-18-2012, 05:48 AM
Z06phile's Avatar
It will work. I put 255 Kumho XSs on all 4 stock wheels.
The pinch wasn't too bad and there was roughly 3/4" more contact patch than a 225 XS mounted on a stock front. I never tried it, but I took them to an event for a friend with an '07.
He did 4 runs on a 235/255 set and 4 on the 255x4 set. He was .8 faster on the 255x4 set.
A stiffer front bar will transform the car. You will be amazed at how much sooner you can get on the gas. Once you get used to that you will smoke that Mustang's pax
etang789
09-01-2019 07:14 AM
dbwy111
01-21-2016 09:41 AM
needanotherS2K
06-19-2012 08:04 PM
08YellowCR
05-22-2010 09:00 PM
SRR
04-13-2008 12:30 PM
Quick Reply: 255's
