Another dumb question.... CR height. Static.
A CR at standstill is the same height as a non CR S2000, even though the CR springs are almost a full inch +/- shorter both front and rear than an 00-01 S2000?
I did the conversion to the CR springs and shocks. Same height. If you want lower, plenty of people have recommended the Swift Spec R springs that can be swapped with the CR springs. I'm considering that, but since I do a lot of mountain driving, I prefer to keep it at it's current height now.
The CR springs are in fact shorter than every other OEM s2000 spring produced by Honda/SHOWA.
Front springs are 79% more stiff over MY00-01 and rears are ~20% more stiff than MY00-01.
With a lighter chassis and stiffer suspension it likely balances out ride height between the AP1 and CR, however I've never measured both cars side by side.
-Ira
-Ira
-Ira
-Ira
