S2000 CR Club Racer Edition CR stands for "club racer," conjuring up the good old days when guys drove their sports cars to the track, raced them, and then, if the racing gods were smiling, drove them home again
Coilovers on CR
Old 01-30-2013, 11:37 PM
michaellongle's Avatar
Default Coilovers on CR
I was wondering how many CR owners has gone the coilovers route and how does it compare to the CR struts and springs?
Just mainly your insight on the subject
How does it change the way the car handle? The geometry of car?
I want to lower my CR but idk which route to go. I read the "Swift R springs" thread and everyone seen to recommend it.
The only thing that bothers me about that is aftermarket springs on stock struts will reduce the life span of the struts in the long run. correct me if im wrong.
Old 01-31-2013, 12:26 AM
takchi's Avatar
I have the Tein SRCs that are valved similar to the Evasive Spec except better. You can always fix geometry with roll center adjusters. Although not necessary, it's recommended if you're lowered enough.
Old 01-31-2013, 01:05 AM
16k spring rate
How's your spine doing lol. How do you like them so far?
Old 01-31-2013, 08:00 AM
psychoazn's Avatar
Don't be fooled by spring rate. People think higher spring rate = worse ride, because, frankly, cheap coilovers ride like ass.
I have a set of custom valved SRCs on my CR too at the moment
Old 01-31-2013, 11:33 AM
Biohazard's Avatar
I am looking at Ohlins sport track kit my CR.
Old 01-31-2013, 06:13 PM
#172CR's Avatar
https://www.s2ki.com/s2000/topic/873...t__p__20645130
Old 01-31-2013, 07:34 PM
s2k4life_az's Avatar
Ohlins, Moton, KWV3 are probably the best in that order but very expensive. The CR suspension and geometry was a major reason of why I wanted the CR over the base model. With that in mind, I'm reluctant to change that setup which would ultimately change my ride geometry and that "CR handling" that we all rave about all the time. However, seeing adrs2k's Swift Springs in person many times, riding with him on the track, and the close spring rates to that of the OEM CR springs, I'm starting to change my viewpoint towards getting those.
The other option, buy another S2K and set that up with the coil overs for comparison.
adrs2k
12-16-2014 07:32 AM
terrors75
12-24-2013 09:20 AM
Cronic
11-17-2010 02:15 PM
08S2KCR
08-11-2008 02:38 PM
Quick Reply: Coilovers on CR
