CR Delete Model - Blank Radio Controls
Hello Everyone,
Does anyone know the part numbers for these blank delete buttons? These are found on the CR delete model, https://cimg4.ibsrv.net/gimg/www.s2k...39a72c5bca.jpg Looking to purchase the OEM parts from Majestic. Thanks in advance. Chris |
I can't find the part number for it... Hell i cant even find it.
It's located under the switch tab when you're on Honda
This is the part number that pulled up for a 2008 CR and the A/C delete: 35880-S2A-A31 2008 base: 35880-S2A-A22 I'm not sure if the CR part number means that it's the blank switch unit. It costs $234 which is the same as the base unit that actually has the radio internals. Logically, you would think the blank that has no internals would be cheaper, which makes me question if it's actually the blank. Very interesting. Will have to dig into this more as this is something I was planning to do on mine as well. |
Whatcha trying to do? I'd be shocked if there were spare panel parts for the CR radio delete model since only a few dozen were ever produced. The standard switch panel is probably going to be available as a used part on Ebay and can be painted to block out the lettering, or perhaps the lettering can be removed with a solvent. If that's what you're trying to do.
Looking at the photo the CR-radio delete panel may have all the switches in there, just absent the lettering which means it'll be as expensive at the base panel. -- Chuck |
I confirmed. Its the blank panel.
They left the best button fully functional. :)
For those interested, we could potentially make a full carbon panel cover that only has the START button if you want.
PM to discuss and if we get enough interest we can create one. thanks |
