S2000 CR Club Racer Edition CR stands for "club racer," conjuring up the good old days when guys drove their sports cars to the track, raced them, and then, if the racing gods were smiling, drove them home again
Cr steering rack stiffer
Old 05-23-2019, 02:12 PM
summitrider2012's Avatar
Default Cr steering rack stiffer
On the back stiffener is there anything that goes between the bracket and subframe to tie it together?
Old 05-23-2019, 02:36 PM
noodels's Avatar
Maybe look on a schematic Honda parts list
Old 05-23-2019, 03:17 PM
i did and it does show a bolt so I was going to install a nursert into my subframe but it doesn’t come close enough to the frame. Anyone have a picture they could share?
Btw it’s not a cr model
Old 05-23-2019, 05:17 PM
9KEVERYDAY's Avatar
The CR model has a specific bracket that is welded to the subframe to accommodate the back steering bracket. You cannot buy this bracket from Honda.
Old 05-24-2019, 02:18 AM
Anyone have a picture of it so I can see if I can duplicate?
Old 05-24-2019, 07:28 AM
9KEVERYDAY's Avatar
I was wanting to accomplish the same thing. I found 1 pic of it on Ebay for sale a while back. CR Subframe. I contacted the seller for more specific pictures and even offered to pay them just for pictures and measurements. No dice. If you do make something and it is functional, I would be very interested in purchasing one from you. Please keep us posted.
Old 05-24-2019, 07:49 AM
9KEVERYDAY's Avatar
Found 2 more images that may be of use.
Not my images, only posted for reference.
Old 05-26-2019, 05:09 PM
zeroptzero's Avatar
Received 3,373 Likes on 2,452 Posts
A nutsert in the frame with a metal spacer or washers to fill the gap with a long bolt will work well enough, that's all you need. It isn't a structural piece, it stiffens up a bit and helps to transmit more feel through the steering system. The front bar does more for stiffening out of the two bars.
Old 05-29-2019, 01:24 AM
I think that’s what I will do. Make a spacer maybe even a box similar to the oem style and just use a nut sert to install it all with a long bolt.
Quick Reply: Cr steering rack stiffer
