Low mileage service schedule
SubscribeThread Starter
Hey guys,
I have a 2008 BB CR with about 25k miles on it. Now that this car is over 10 years old, is any additional service required? I'm planning on doing the serpentine belt this spring but is there anything else to consider outside the standard oil, brake, transmission and diff fluid changes?
Thanks!
James
Thanks!
James
dedonderosa
close
- Join DateMar 2007
Liked:85 Times in 63 Posts
i would do all the maintenance you have listed and also the following.
air filter
cabin filter
Clutch Fluid
Valve adjustment
Spark plugs and torque to 24ft lbs. (NGK recommends every 7 years or 100k miles on plugs )
then everything is done and your good to go!
air filter
cabin filter
Clutch Fluid
Valve adjustment
