matt Farah vs CR
so does anyone know what happened to the GPW CR Matt Farah incident? Looks like Streets of Willow
https://scontent.fsnc1-1.fna.fbcdn.n...0e&oe=5B7833DE |
Wait, so Farah just drove into dude in the CR?
Any update on what appears to have been a possible "track incident" ? Anyone know the CR ?
Was it this car?
(removed image) I am assuming there wasn't actually contact based on the FB post. edit: There was contact, sounds like it was the fault of the Evora, apparently a video will be posted eventually. |
Originally Posted by Chibo
Was it this car?
(removed image) I am assuming there wasn't actually contact based on the FB post. edit: There was contact, sounds like it was the fault of the Evora, apparently a video will be posted eventually. I mean it would be insane to pass on the inside. Actually it's just plain crazy to pass anywhere there unless you absolutely knew where the other driver was gonna go, then maybe you could plan a crossover pass. The easier place for the passing drive to pass would be 1, you can go on the outside or the inside for a block pass but nonetheless it's a track day. So if the other driver isn't going to let you go, no sense in swapping paint |
I assume you found the details through the book of faces?
I know the CR owner and out of respect for his privacy i'll leave him as anonymous.
It was an on track collision that occured between both cars. The CR was not badly damaged and Matt assumed responsibility for the damage. |
