Official CR FAQ
So what exactly differentiates the S2000 CR From the regular s2000 line?
Answer--> https://www.s2ki.com/s2000/topic/863...t__p__20519388 Q: What is the paint code for my color? Answer--> BB = NH-547 ............... https://www.s2ki.com/s2000/gallery/p...262__file__med https://www.s2ki.com/s2000/gallery/p...392__file__med ............... GPW = NH-565 ............... https://www.s2ki.com/s2000/gallery/p...308__file__med https://www.s2ki.com/s2000/gallery/p...404__file__med ............... ABP = B-554P ............... https://www.s2ki.com/s2000/gallery/p...263__file__med https://www.s2ki.com/s2000/gallery/p...396__file__med ............... Rio = Y-65P ............... https://www.s2ki.com/s2000/gallery/p...310__file__med https://www.s2ki.com/s2000/gallery/p...408__file__med What is the color of the "CR silver" wheels? Answer--> The color is called Kaiser silver and the paint code is NH-546M. Is there a way to ID the oem CR springs? Answer--> https://www.s2ki.com/s2000/topic/818...nsion-springs/ What does the CR seat look like and how is it different? Answer-->The CR seat is made of an Alcantara trim and a yellow fabric center https://www.s2ki.com/s2000/gallery/p...411__file__med What is my CR production number? Answer--> Scroll Down What does the inside of the CR muffler look like? Answer-->
Originally Posted by macr88
(Post 22358402)
Here's what a regular exhaust looks like.
https://i1235.photobucket.com/albums...FCC259B190.jpg Here's a CR exhaust. https://i1235.photobucket.com/albums...FCC33314CE.jpg Answer--> Apex Blue Pearl: 200 (21 Delete models) ............... Rio Yellow Pearl: 140 (20 Delete models) ............... Berlina Black: 269 (10 Delete models) ............... Grand Prix White: 90 (8 Delete models) ............... Total 699 (668 for 2008, 31 for 2009) What is the weight of the CR? Answer--> 2,765 lb (1,254 kg)(without hardtop) ............... 2,813 lb (1,276 kg)(with hardtop) ............... 2,855 lb (1,295 kg)(with hardtop + audio + AC) ............... Weight of standard MY08 & MY09 s2000, 2,864 lb (1,299 kg) What were the MSRP's of the CR? Answer--> 2008 S2000 CR (air conditioning and audio system deleted) - $36,300 ............... S2000 CR (air conditioning and audio system included) - $37,300 ............... 2009 S2000 CR (air conditioning and audio system deleted) - $36,795 ............... S2000 CR (air conditioning and audio system included) - $37,795 The CR doesn't have a spare tire, so whats in its place? Answer-->Nothing...The reinforced chassis brace is located above where the spare tire goes. The CR does come with an air pump/tire patch kit; ............... https://i6.photobucket.com/albums/y2...o/HPIM0037.jpg What should I look for when potentially buying a CR compared to a regular s2000?
Originally Posted by CR Matey!
(Post 20686990)
- Misc Parts: As the others mentioned, the two triangle pieces (should match the color of the car) is meant to cover up openings from the roof then you remove them. Is the tool kit in the trunk? Verify that the roof can come off and on and there are no alignment issues with the seals/windows.
- Originals: Verify that the seats, wheels, shift knob, etc. are for the CR and not generic S2K replacements. Signs of a break in and replaced with non-CR parts. May not mean much to some people and the value, but allows you to see if the seller is transparent and can be trusted. - Carfax: See how many previous owners, see if the mileage is consistent (it is easy to hack the odo or swap in another odo), look for history of any accidents, if the title is clean. If you scan the VIN and the owner(s) is registered here, you can glean a bit of the cars history by scanning their posts. Good luck! Answer--> https://www.s2ki.com/s2000/topic/863...nd-trunk-info/ What are some storage tips for storing my CR when its not being driven? Answer--> https://www.s2ki.com/s2000/topic/908...o-store-08-cr/ What is different about the gauge cluster? Answer--> The CR bezel has yellow markings instead of white, and has a peak power indicator that flashes green ............... CR Cluster ............... ................https://cimg7.ibsrv.net/gimg/www.s2k...064a407ca1.jpg ............... AP2 v2 Cluster ............... https://i5.photobucket.com/albums/y1...3/IMG_0320.jpg CR Specific Videos CR Specific articles and publications Answer-->Modern collectibles revealed: 2008-2009 Honda S2000 CR Answer-->Road and Track: Sayonara to the s2000 CR; Road Test Answer-->Automobile Magazine: 2009 Honda s2000 CR Answer-->Edmunds Inside Line: First Drive 2008 Honda s2000 CR Answer-->Car and Driver: Honda builds a club racer Answer-->Bloomberg Business: Cool Racer. Is this really a Honda? Answer-->I Race a Honda: Robert Thorne ~ Honda Performance Development |
Q: What is the S2K Spring Rate and Part number?
Front Springs: 51401-S2A-S21 Honda Color Coding: Blue Yellow Orange Spring Rate: 391 in/lbs or 7.0 kg/mm (Base S2000 4.75 kg/mm) (Thanks Mchester) Free Length: 9.89in Rear Springs: 52441-S2A-S21 Honda Color Coding: Blue Orange Orange Spring Rate: 346 in/lbs or 6.2 kg/mm (Base S2000 4.88 kg/mm) (Thanks Mchester) Free Length: 10.13in Front Sway bar: 51300-S2A-S11 Diameter: 28.6mm Thickness: 4.5mm Measured Spring Rate: 392 lb/in Rear Sway bar: 52300-S2A-S01 Diameter: 26.5 Thickness: 4.5 Measured Spring Rate: 362 lb/in Source: http://www.mccanless.net/Characteriz...rings_rev1.pdf (John McCanless aka twohoos) Q: What is the factory CR Alignment? Front: -0.50 degrees camber 6.00 degrees caster 0 toe Rear: -1.50 degrees camber 0.22in (5.5mm) total toe in For reference, the only change to other year alignment is toe-in on the rear: 00-03: 0.24in (6.0mm) total toe in 04-09: 0.14in (3.6mm) total toe in Please note that these are for US spec cars. Source: 08 S2000 Service Manual Q: How can you tell if a car is a CR by VIN number? J HM AP2 1 2 * 8 S 000001 J = Japanese built (Made in Japan) HM = Honda Motor Company passenger vehicle AP2 = Chassis code S2000/F22C1 (AP1 for 00-03) 1 = 2 door convertible/6 speed manual 2 = CR (4 = base S2000) * = check digit (Varies by car) 8 = Model year (0-9) S = Built at Suzuka factory (T = Tochigi; AP1s and early AP2s) 000001 = Serial Number Q: Swift Spec R spring reviews with CR suspension https://www.s2ki.com/s2000/topic/933...spec-r-review/ https://www.s2ki.com/s2000/topic/977...pec-r-springs/ |
1 Attachment(s)
The rear view mirrow placement on the CR is higher on the windshield vs. a base S2000
I guess the reason is for it to see over the tonneau cover I found out the hard way as a Broadway mirror will not fit properly luckily the mirror was free Attachment 109355 |
CR Specific parts and their associated Honda part number
CR wheels ........42700-S2A-A61 - Rear 17x8.5 ........44700-S2A-A61 - Front 17x7 CR OEM Tires - Bridgestone Potenza RE-070 ........42751-BRI-101 - 215/45R17 ........42751-BRI-102 - 255/40R17 CR hardtop ........69100-S2A-901ZZ - Panel Only CR Tonneau - Can only be purchased as complete Unit (stays, seals etc) ........86380-S2A-A00ZA - Apex Blue Pearl ........86380-S2A-A00ZB - Berlina Black ........86380-S2A-A00ZC - Grand Prix White ........86380-S2A-A00ZD - Rio Yellow Pearl CR Tonneau Bolt Cap Cover ........86384-S2A-A00ZD - Rio Yellow Pearl ........86384-S2A-A00ZA - Apex Blue Pearl ........86384-S2A-A00ZB - Berlina Black ........86384-S2A-A00ZB - Grand Prix White CR Tonneau Corners ........86386-S2A-A00ZD - Rio Yellow Pearl Passenger ........86396-S2A-A00ZD - Rio Yellow Pearl Driver ........86386-S2A-A00ZC - Grand Prix White Passenger ........86396-S2A-A00ZC - Grand Prix White Driver ........86386-S2A-A00ZB - Berlina Black Passenger ........86396-S2A-A00ZB - Berlina Black Driver ........86386-S2A-A00ZA - Apex Blue Pearl Passenger ........86396-S2A-A00ZA - Apex Blue Pearl Driver CR Seat Trim Covering ........81521-S2A-A61ZB - Driver Upper Cover ........81121-S2A-A61ZB - Passenger Upper Cover ........81531-S2A-A61ZB - Driver Lower Cover ........81131-S2A-A61ZB - Passenger Lower Cover CR Door inserts ........83580-S2A-A71ZA - Driver ........83530-S2A-A71ZA - Passenger CR Steering wheel ........78501-S2A-A72ZC CR Specific Center Console Pieces ........83403-S2A-G51ZD - Garnish Around Buttons ........77232-S2A-A51ZD - CR cup holder/lid assembly CR soft top delete button ........83405-S2A-A01ZA CR Front Suspension (Springs + Shocks) ........51620-S2A-S21 - Complete Front Driver ........51610-S2A-S21 - Complete Front Passenger ........51612-S2A-S21 - Front Driver Shock ........51611-S2A-S21 - Front Passenger Shock ........51401-S2A-S21 - Front Spring CR Rear Suspension (Springs + Shocks) ........52620-S2A-S21 - Complete Rear Driver ........52610-S2A-S21 - Complete Rear Passenger ........52612-S2A-S21 - Rear Driver Shock ........52611-S2A-S21 - Rear Passenger Shock ........52441-S2A-S21 - Rear Spring CR Front Sway ........51300-S2A-S11 CR Rear Sway ........52300-S2A-S01 CR Specific Car Cover ........08P34-S2A-100A CR Front bumper ........04711-S2A-A80ZZ - un painted CR Front Under Spoiler ........71110-S2A-A00ZA - Apex Blue Pearl ........71110-S2A-A00ZB - Berlina Black ........71110-S2A-A00ZC - Grand Prix White ........71110-S2A-A00ZD - Rio Yellow Pearl CR Front Tow Hook Cover ........71104-S2A-010ZB - Berlina Black ........71104-S2A-010ZC - Grand Prix White ........71104-S2A-010ZS - Rio Yellow Pearl ........71104-S2A-010ZV - Apex Blue Pearl CR License Plate Hole Plugs ........90672-S2A-A00ZB - Berlina Black ........90672-S2A-A00ZC - Grand Prix White ........90672-S2A-A00ZK - Rio Yellow Pearl ........90672-S2A-A00ZQ - Apex Blue Pearl CR Rear Tow Hook Cover ........71504-S2A-010ZV - Apex Blue Pearl ........71504-S2A-010ZS - Rio Yellow Pearl ........71504-S2A-010ZC - Grand Prix White ........71504-S2A-010ZB - Berlina Black CR Wing (wing only) ........71701-S2A-A01ZK - CR Wing RYP ........71701-S2A-A01ZD - CR Wing GPW ........71701-S2A-A01ZC - CR Wing BB ........71701-S2A-A01ZB - CR Wing ABP CR Wing Stands ........71711-S2A-A01ZL - CR Wing Stand Outer Right RYP ........71712-S2A-A01ZL - CR Wing Stand Inner Right RYP ........71761-S2A-A01ZL - CR Wing Stand Outer Left RYP ........71762-S2A-A01ZL - CR Wing Stand Inner Left RYP ........71711-S2A-A01ZE - CR Wing Stand Outer Right GPW ........71712-S2A-A01ZE - CR Wing Stand Inner Right GPW ........71761-S2A-A01ZE - CR Wing Stand Outer Left GPW ........71762-S2A-A01ZE - CR Wing Stand Inner Left GPW ........71711-S2A-A01ZD - CR Wing Stand Outer Right BB ........71712-S2A-A01ZD - CR Wing Stand Inner Right BB ........71761-S2A-A01ZD - CR Wing Stand Outer Left BB ........71762-S2A-A01ZD - CR Wing Stand Inner Left BB ........71711-S2A-A01ZC - CR Wing Stand Outer Right ABP ........71712-S2A-A01ZC - CR Wing Stand Inner Right ABP ........71761-S2A-A01ZC - CR Wing Stand Outer Left ABP ........71762-S2A-A01ZC - CR Wing Stand Inner Left ABP CR Trunk Springs (these will make the trunk FLY open without the CR wing or bigger) ........74871-S2A-A00 - Right ........74872-S2A-A00 - Left CR Trunk ........68500-S2A-A80ZZ CR Trunk Reinforcements ........74492-S2A-A00 - Under Trunk Edge Driver Side ........74442-S2A-A00 - Under Trunk Edge Passenter Side ........74827-S2A-A00 - Under Rear Edge ........74443-S2A-A00 - Trunk Side CR Stiffening Bar (Behind Seat) ........74680-S2A-A10 CR Exhaust ........18030-S2A-S00 CR Stiffener ........53437-S2A-S00 CR Outer Door Handle ........72180-S86-K02A2 - Rio Yellow Pearl ........72180-S86-K02A5 - Apex Blue Pearl ........72180-S86-K02YA - Berlina Black ........72180-S86-K02YB - Grand Prix White CR Floor Mats ........83600-S2A-A01ZE - Floor Mat Set ........83602-S2A-A01ZE - Driver Side ........83601-S2A-A01ZE - Passenger Side CR Radio Door ........77252-S2A-902ZG CR Gauge Cluster ........78130-S2A-A21 LCD Assembly CR Black emblems ........75710-S2A-A00 - S ........75711-S2A-A00 - 2000 ........75710-S2A-A01 - C ........75711-S2A-A01 - R CR Side Markers ........33801-S2A-J02 ........33851-S2A-J02 CR Delete AC serpentine belt ........31110-PCX-G01 CR Shift Boot ........83414-S2A-A62ZA CR Shift knob ........54102-S2A-C00 CR Spare tire delete kit ........89101-S2A-A00 - Foam Box ........38160-S2A-014 - Air Pump ........42774-S2A-A02 - Tire Puncture Kit (Fix a flat, patch, directions) CR Steering Rack ........53439-S2A-S01 CR Delete A/C Button ........79612-S2A-E11 CR Roll Hoops ........84515-s2A-A60ZA - Right Roll Hoop ........84565-s2A-A60ZA - Left Roll Hoop CR Hardtop Defroster Sub-Harness ........32204-S2A-030 CR VSA modulator (computer) ........57110-S2A-S01 CR Sub-Frame ........50200-S2A-A00 CR Cabin Wire Harness ........32100-S2A-A20 CR Wire Harness, R.R. ........32108-S2A-A20 CR Wire Harness, Instrument ........32117-S2A-A20 CR Wire Harness, Dashboard ........32150-S2A-A20 CR Wire Harness, Driver Door ........32751-S2A-A20 CR Wire Harness, Dashboard ........32752-S2A-A20 CR Tower Bar ........74610-S2A-010ZZ CR Cluster Housing ........78110-S2A-A31 - This is the housing for the cluster. The CR housing includes a prism and a lens for the peak power LED. The base housing is missing both items. CR Cluster Circuit Board ........78146-S2A-A31 - This is the circuit board for the cluster. This includes the Peak Power LED and driver circuit. The LED and driver are not included on the base model circuit board. CR Cluster Lens ........78170-S2A-A31 - This is the lens cover. The only difference between the CR vs base model is the use of yellow instead of silver along the tachometer, temperature, and fuel indicators. |
CR Production Numbers. Located the last 4 digits of your VIN for the corresponding production number. Additionally please see that if the VIN has a thread already created for that vehicle, it is linked here with a clickable hyper link on the listing.:
2008 CR's Delete or AC model ........................,...........Color .......... Interior ...... VIN..... CR # Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000007 1 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000008 2 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000019 3 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000020 4 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000021 5 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000022 6 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000023 7 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000024 8 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000025 9 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000026 10 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000027 11 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000040 12 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000041 13 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000042 14 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000043 15 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000044 16 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000045 17 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000046 18 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000047 19 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000048 20 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000056 21 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000057 22 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000058 23 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000059 24 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000060 25 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000061 26 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000062 27 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000063 28 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000064 29 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000071 30 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000072 31 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000073 32 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000074 33 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000075 34 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000076 35 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000077 36 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000078 37 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000079 38 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000083 39 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000084 40 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000085 41 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000086 42 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000087 43 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000088 44 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000089 45 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000090 46 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000091 47 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000108 48 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000109 49 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000110 50 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000111 51 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000112 52 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000113 53 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000114 54 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000115 55 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000116 56 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000133 57 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000134 58 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000135 59 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000136 60 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000137 61 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000138 62 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000139 63 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000140 64 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000141 65 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000158 66 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000159 67 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000160 68 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000161 69 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000162 70 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000163 71 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000164 72 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000165 73 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000166 74 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000183 75 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000184 76 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000185 77 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000186 78 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000187 79 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000188 80 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000189 81 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000190 82 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000191 83 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000208 84 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000209 85 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000210 86 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000211 87 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000212 88 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000213 89 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000214 90 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000215 91 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000216 92 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000233 93 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000234 94 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000235 95 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000236 96 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000237 97 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000238 98 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000239 99 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000240 100 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000241 101 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000253 102 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000254 103 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000255 104 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000256 105 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000257 106 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000258 107 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000259 108 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000260 109 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000261 110 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000274 111 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000275 112 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000276 113 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000277 114 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000278 115 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000279 116 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000280 117 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000281 118 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000282 119 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000295 120 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000296 121 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000297 122 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000298 123 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000299 124 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000300 125 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000301 126 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000302 127 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000303 128 Club Racer 6 Speed Manual Grand Prix White Yellow/Black 000314 129 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000315 130 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000316 131 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000317 132 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000318 133 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000319 134 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000320 135 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000321 136 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000322 137 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000335 138 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000336 139 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000337 140 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000338 141 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000339 142 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000340 143 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000341 144 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000342 145 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000343 146 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000356 147 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000357 148 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000358 149 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000359 150 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000360 151 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000361 152 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000362 153 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000363 154 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000364 155 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000377 156 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000378 157 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000379 158 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000380 159 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000381 160 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000382 161 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000383 162 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000384 163 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000385 164 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000398 165 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000399 166 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000400 167 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000401 168 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000402 169 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000403 170 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000404 171 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000405 172 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000406 173 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000446 174 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000447 175 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000448 176 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000449 177 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000450 178 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000451 179 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000452 180 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000453 181 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000454 182 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 000463 183 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 000464 184 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000465 185 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000466 186 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000467 187 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000468 188 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000469 189 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000470 190 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000471 191 Club Racer 6 Speed Manual Berlina Black Yellow/Black 000474 192 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 000475 193 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000476 194 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000477 195 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000478 196 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000479 197 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000480 198 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000481 199 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000482 200 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 000489 201 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000490 202 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000491 203 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000492 204 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000493 205 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000494 206 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000502 207 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000503 208 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000504 209 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000505 210 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000506 211 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000507 212 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000515 213 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000516 214 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000517 215 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000518 216 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000519 217 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000520 218 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000521 219 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000522 220 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000532 221 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000533 222 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000534 223 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000535 224 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000536 225 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000537 226 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000547 227 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000548 228 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000549 229 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000550 230 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000551 231 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000552 232 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000563 233 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000564 234 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000565 235 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000566 236 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000567 237 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000568 238 Club Racer 6 Speed Manual Berlina Black Yellow/Black 000576 239 Club Racer 6 Speed Manual Berlina Black Yellow/Black 000577 240 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000578 241 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000579 242 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000580 243 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000581 244 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000582 245 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000583 246 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000584 247 Club Racer 6 Speed Manual Grand Prix White Yellow/Black 000594 248 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000595 249 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000596 250 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000597 251 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000598 252 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000599 253 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000608 254 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000609 255 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000610 256 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000611 257 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000612 258 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000613 259 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 000622 260 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000623 261 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000624 262 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000625 263 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000626 264 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000627 265 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000628 266 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000629 267 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000630 268 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000643 269 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000644 270 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000645 271 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000646 272 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000647 273 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000648 274 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000661 275 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000662 276 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000663 277 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000664 278 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000665 279 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000666 280 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000679 281 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000680 282 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000681 283 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000682 284 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000683 285 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000684 286 Club Racer 6 Speed Manual Berlina Black Yellow/Black 000697 287 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000698 288 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000699 289 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000700 290 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000701 291 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000702 292 Club Racer 6 Speed Manual Grand Prix White Yellow/Black 000715 293 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000716 294 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000717 295 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000718 296 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000719 297 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000720 298 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000732 299 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000733 300 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000734 301 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000735 302 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000736 303 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000737 304 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 000747 305 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000748 306 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000749 307 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000750 308 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000751 309 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000752 310 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000767 311 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000768 312 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000769 313 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000770 314 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000771 315 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000772 316 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000785 317 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000786 318 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000787 319 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000788 320 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000789 321 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000790 322 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000801 323 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000802 324 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000803 325 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000804 326 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000817 327 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000818 328 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000819 329 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000820 330 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000821 331 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000822 332 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 000834 333 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 000835 334 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000836 335 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000837 336 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000838 337 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000839 338 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000851 339 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000852 340 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000853 341 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000854 342 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000855 343 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000856 344 Club Racer 6 Speed Manual Berlina Black Yellow/Black 000868 345 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000869 346 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000870 347 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000871 348 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000872 349 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000873 350 Club Racer 6 Speed Manual Berlina Black Yellow/Black 000885 351 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000886 352 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000887 353 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000888 354 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000889 355 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000890 356 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000902 357 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000903 358 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000904 359 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000905 360 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000906 361 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000907 362 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000920 363 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000921 364 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000922 365 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000923 366 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000924 367 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000925 368 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 000938 369 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000939 370 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000940 371 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000941 372 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000942 373 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000943 374 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000956 375 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000957 376 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000958 377 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000959 378 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000960 379 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000961 380 Club Racer 6 Speed Manual Berlina Black Yellow/Black 000974 381 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000975 382 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000976 383 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000977 384 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000978 385 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000979 386 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 000992 387 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000993 388 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000994 389 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000995 390 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000996 391 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000997 392 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001010 393 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001011 394 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001012 395 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001013 396 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001014 397 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001015 398 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 001028 399 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001029 400 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001030 401 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001031 402 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001032 403 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001033 404 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 001046 405 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 001047 406 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001048 407 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001049 408 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001050 409 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001051 410 Club Racer 6 Speed Manual Berlina Black Yellow/Black 001064 411 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001065 412 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001066 413 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001067 414 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001068 415 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001069 416 Club Racer 6 Speed Manual Grand Prix White Yellow/Black 001082 417 Club Racer 6 Speed Manual Grand Prix White Yellow/Black 001083 418 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001084 419 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001085 420 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001086 421 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001087 422 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001118 423 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001119 424 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001120 425 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001121 426 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001122 427 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001123 428 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 001137 429 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 001138 430 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001139 431 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001140 432 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001141 433 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001142 434 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 001156 435 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001157 436 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001158 437 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001159 438 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001160 439 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001161 440 Club Racer 6 Speed Manual Berlina Black Yellow/Black 001177 441 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001178 442 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001179 443 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001180 444 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 001197 445 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 001198 446 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001199 447 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001206 448 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001207 449 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001208 450 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001209 451 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001217 452 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001218 453 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001219 454 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001226 455 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001227 456 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001228 457 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001229 458 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001230 459 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001231 460 Club Racer 6 Speed Manual Berlina Black Yellow/Black 001238 461 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001239 462 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001240 463 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001241 464 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001242 465 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001243 466 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 001250 467 Club Racer 6 Speed Manual Grand Prix White Yellow/Black 001251 468 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001252 469 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001253 470 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001254 471 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001255 472 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001263 473 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001264 474 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001265 475 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001273 476 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001274 477 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001275 478 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001288 479 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001289 480 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 001298 481 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001299 482 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001300 483 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001301 484 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001302 485 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001303 486 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001312 487 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001313 488 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001314 489 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001315 490 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001316 491 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001317 492 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001329 493 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001330 494 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001331 495 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 001343 496 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001344 497 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001345 498 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001357 499 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001358 500 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001359 501 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001368 502 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001369 503 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001370 504 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001371 505 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001372 506 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001373 507 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001383 508 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001384 509 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001385 510 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001386 511 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001387 512 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001400 513 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001401 514 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001402 515 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 001414 516 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001415 517 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001416 518 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 001425 519 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001426 520 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001427 521 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001428 522 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001429 523 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001430 524 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001439 525 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001440 526 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001441 527 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001442 528 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001443 529 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001444 530 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 001453 531 Club Racer 6 Speed Manual Grand Prix White Yellow/Black 001454 532 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001455 533 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001456 534 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001457 535 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001458 536 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001467 537 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001468 538 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001476 539 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001477 540 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001478 541 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001486 542 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001487 543 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001488 544 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001492 545 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001493 546 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001494 547 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001502 548 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001503 549 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001510 550 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001511 551 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001512 552 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001519 553 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001520 554 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001521 555 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001528 556 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001529 557 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001530 558 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001537 559 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001538 560 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001539 561 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001547 562 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001548 563 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001549 564 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001557 565 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001558 566 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001559 567 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001567 568 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001568 569 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001569 570 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001577 571 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001578 572 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001579 573 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001587 574 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001588 575 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001589 576 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001596 577 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001597 578 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001598 579 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001605 580 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001606 581 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001607 582 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001614 583 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001615 584 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001616 585 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001623 586 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001624 587 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001625 588 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001641 589 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001642 590 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001651 591 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001652 592 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001653 593 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001662 594 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001663 595 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001664 596 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001673 597 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001674 598 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001675 599 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001686 600 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001706 601 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001707 602 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001708 603 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001717 604 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001718 605 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001719 606 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001727 607 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001728 608 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001729 609 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001739 610 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001755 611 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001756 612 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001757 613 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001765 614 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001766 615 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001767 616 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001775 617 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001776 618 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001777 619 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001805 620 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001806 621 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001807 622 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001816 623 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001817 624 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 001860 625 Club Racer 6 Speed Manual Apex Blue Pearl Yellow/Black 001861 626 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001862 627 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001877 628 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001878 629 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001879 630 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001894 631 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001895 632 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001896 633 Club Racer 6 Speed Manual Rio Yellow Pearl Yellow/Black 001914 634 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001940 635 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001941 636 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 001942 637 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001957 638 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001958 639 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001959 640 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 001974 641 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 001975 642 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001976 643 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 001993 644 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 002026 645 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 002027 646 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 002028 647 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 002041 648 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 002042 649 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 002043 650 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 002211 651 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 002212 652 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 002213 653 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 002214 654 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 002291 655 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 002292 656 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 002293 657 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 002311 658 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 002333 659 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 002334 660 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 002335 661 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 002343 662 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 002344 663 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 002345 664 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 002359 665 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 002360 666 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 002361 667 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 002378 668 2009; CR# Year .. Model .................................................. ...Color ............... Interior ...... VIN Serial 669 2009 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000100 670 2009 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000101 671 2009 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000102 672 2009 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000103 673 2009 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000104 674 2009 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000105 675 2009 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000110 676 2009 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000111 677 2009 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000112 678 2009 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000125 679 2009 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000126 680 2009 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000176 681 2009 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000177 682 2009 Club Racer with A/C & Audio 6 Speed Manual Apex Blue Pearl Yellow/Black 000178 683 2009 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000183 684 2009 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000198 685 2009 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000199 686 2009 Club Racer with A/C & Audio 6 Speed Manual Rio Yellow Pearl Yellow/Black 000200 687 2009 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000329 688 2009 Club Racer 6 Speed Manual Grand Prix White Yellow/Black 000336 <---This is the only MY09 Delete 689 2009 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000337 690 2009 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000338 691 2009 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000349 692 2009 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000350 693 2009 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000351 694 2009 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000352 695 2009 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000353 696 2009 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000354 697 2009 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000355 698 2009 Club Racer with A/C & Audio 6 Speed Manual Grand Prix White Yellow/Black 000356 699 2009 Club Racer with A/C & Audio 6 Speed Manual Berlina Black Yellow/Black 000357 |
Interesting dealer type video on the Honda S2000 CR
http://videos.autos.aol.com/2008-hon...rive-517579882 |
Just a FYI for you delete CR owners. The original fan belt specified for the our non a/c CR's is no longer available (according to Majestic Honda) and has been replaced by the a/c model belt.
Non A/C serpentine belt: 31110-PCX-G01. no longer available. Honda specified belt for a/c and non a/c CR's: A/C serpentine belt: 31110-PCX- 505 A possible alternative to the G01 belt is the Goodyear Gatorback 4060450 6PK1145. |
Originally Posted by Vanishing Point
Just a FYI for you delete CR owners. The original fan belt specified for the our non a/c CR's is no longer available (according to Majestic Honda) and has been replaced by the a/c model belt. Non A/C serpentine belt: 31110-PCX-G01. no longer available. Honda specified belt for a/c and non a/c CR's: A/C serpentine belt: 31110-PCX- 505 A possible alternative to the G01 belt is the Goodyear Gatorback 4060450 6PK1145.
Ira.
Found this information in another thread concerning the CR gauge bezel and it's CR specific parts. There are three parts that are different in the CR cluster vs the base 08/09 cluster. 1. 78110-S2A-A31 - This is the housing for the cluster. The CR housing includes a prism and a lens for the peak power LED. The base housing is missing both items. 2. 78146-S2A-A31 - This is the circuit board for the cluster. This includes the Peak Power LED and driver circuit. The LED and driver are not included on the base model circuit board. 3. 78170-S2A-A31 - This is the lens cover. The only difference between the CR vs base model is the use of yellow instead of silver along the tachometer, temperature, and fuel indicators. |
Nice find steven!
