Swift Spec R.... Review
#102
Takchi I believe posted when swift was working on the spec r, I thought someone said they provided analysis of the testing on the cr strut. If anyone has concerns I would assume contacting swift regarding it for a copy of the research.
#103
Swift says that they were based on what the stock shocks can handle.
"2 Increase in spring rate to further enhance cornering speed through entry & exit. The increase in spring rate is based on the vehicle factory stock valving settings. Sport Springs Spec-R is increase to the optimal rate that the stock shocks can handle. Higher performance shocks are not required, but recommended."
I'm sure I'm doing any favors to my stock shocks and I'm sure they will wear quicker now, but according to Swift there should not be any direct issues. All of their information states AP1/2 and '00-'09.
#104
Keep in mind all lowering springs decrease the life of OEM dampers. Swift Springs just did their homework, research, and testing much better than the other manufacturers. Hope that information helps.
#105
Keep in mind all lowering springs decrease the life of OEM dampers. Swift Springs just did their homework, research, and testing much better than the other manufacturers. Hope that information helps. />
#106
Originally Posted by takchi' timestamp='1353369294' post='22160848
[quote name='maranelloboy05' timestamp='1353367614' post='22160797']
Keep in mind all lowering springs decrease the life of OEM dampers. Swift Springs just did their homework, research, and testing much better than the other manufacturers. Hope that information helps. />/>
[/quote]
Sorry I need to make a correction. The nice drop look is the maximum drop before you run out of decent shock travel. A lot of lowering springs forget to take that into consideration as well.
#107
Thanks for posting that up David.
#108
Originally Posted by maranelloboy05' timestamp='1353372856' post='22160963
[quote name='takchi' timestamp='1353369294' post='22160848']
Keep in mind all lowering springs decrease the life of OEM dampers. Swift Springs just did their homework, research, and testing much better than the other manufacturers. Hope that information helps. />/>/>
[/quote]
[/quote]
Ah, ok, definitely seems like they put a lot more effort into these than other spring companies. I thought the springs would be too low when I got them, but it came out really nice. Also, I didn't see any "settling" from the time they were installed until now, looks exactly the same, but correct me if I'm wrong Swift says there is no settling on these.
#109
Originally Posted by takchi' timestamp='1353374878' post='22161021
[quote name='maranelloboy05' timestamp='1353372856' post='22160963']
Keep in mind all lowering springs decrease the life of OEM dampers. Swift Springs just did their homework, research, and testing much better than the other manufacturers. Hope that information helps. />/>/>/>
[/quote]
[/quote]
[/quote]
You are correct. Swift springs don't settle. The reason being is that highend spring companies use methods to make sure their springs maintain their effective rates, shape, physical dimensions, etc. If you're looking for springs on coilovers, Hyperco and Swift are the top companies to go with because their spring rates are extremely linear, they are lighter, and they do not settle. It makes a significant difference when you're tuning your suspension. It also makes crappy coilovers feel acceptable. That's how effective springs are. Now shock valving is a different story. I turn that topic to adrs2k.
#110
