Wilwood BBK Installed (Stock CR wheels)
Update: Just got back from a 3hr early morning (5am start) backroad mischief across three states. I m sure I had the rotors glowing, needless to say, the brakes functioned without fail. These brakes are better then I expected.
The KW V2's came in today however. Though Im not going to install them for a few weeks. I have been too busy at work. I just cleared off my work scheule today so I can take off to the woods. Bathe in the creek, eat squirrels and barries. Maybe a few insects. I'll be back in a week or two. Got to clear my mind.
How good do you think the clearance would be with say a 5mm spacer and 225 tires?
EDIT: I'll check out the tire guide myself to see if I can find my own answer haha
With the 225 he's also getting 5mm of extra tire on each side of the wheel and a little more rolling diameter, too. How much camber do you have in the front, Eric? You may want to pick up the spacers and drive around with them on for a while before you pull the trigger on the BBK.
