Go Back  S2KI Honda S2000 Forums > Special Interest > S2000 CR Club Racer Edition
Reload this Page >
Wilwood BBK Installed (Stock CR wheels)
S2000 CR Club Racer Edition CR stands for "club racer," conjuring up the good old days when guys drove their sports cars to the track, raced them, and then, if the racing gods were smiling, drove them home again
Old 08-10-2012, 12:24 PM
Site Moderator
Manga_Spawn's Avatar
You could probably run a 5mm spacer and it would be fine. That looks so incredibly close.
Manga_Spawn is online now
Old 08-10-2012, 02:34 PM
Go2
Originally Posted by JoeyBalls View Post
You wouldnt happen to know the offset for the CR rims would ya?
fronts are +55, rears are +65
Go2 is offline
Old 08-10-2012, 02:35 PM
Go2
Go2 is offline
Old 08-12-2012, 06:21 AM
TheSnail's Avatar
Update: Just got back from a 3hr early morning (5am start) backroad mischief across three states. I m sure I had the rotors glowing, needless to say, the brakes functioned without fail. These brakes are better then I expected.
TheSnail is offline
Old 08-14-2012, 03:22 PM
what size tires are you running and what alignment? no issues with rubbing?
ericshun is offline
Old 08-14-2012, 03:43 PM
TheSnail's Avatar
Its stock tire sizes, rims and suspension. A BBK would not affect or be affected by tire size or alignment.
TheSnail is offline
Old 08-14-2012, 03:54 PM
TheSnail's Avatar
The KW V2's came in today however. Though Im not going to install them for a few weeks. I have been too busy at work. I just cleared off my work scheule today so I can take off to the woods. Bathe in the creek, eat squirrels and barries. Maybe a few insects. I'll be back in a week or two. Got to clear my mind.
TheSnail is offline
Old 08-15-2012, 09:35 AM
I know, I was wondering those for sake of rubbing issues due to using a spacer. I would like to run a larger spacer because that small clearance kinda freaks me out. I am also planning on increasing my tire size but if it's going to start rubbing I won't up it since I don't want to roll my fender.
How good do you think the clearance would be with say a 5mm spacer and 225 tires?
EDIT: I'll check out the tire guide myself to see if I can find my own answer haha
ericshun is offline
Old 08-15-2012, 10:13 AM
Vanishing Point's Avatar
At stock ride height you should be fine with the 5MM spacer/tires.
Vanishing Point is online now
Old 08-15-2012, 10:45 AM
odb812's Avatar
With the 225 he's also getting 5mm of extra tire on each side of the wheel and a little more rolling diameter, too. How much camber do you have in the front, Eric? You may want to pick up the spacers and drive around with them on for a while before you pull the trigger on the BBK.
odb812 is offline
Quick Reply: Wilwood BBK Installed (Stock CR wheels)
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
