Wilwood BBK Installed (Stock CR wheels)
#21
wilwoods have known issues if used for track use fyi, if just being used for spirited driving and daily use they are fine, but alot of failures occurring on the track due to extra sustained heat loads. Pistons seizing up.
#22
Originally Posted by Vanishing Point' timestamp='1345054386' post='21939434
At stock ride height you should be fine with the 5MM spacer/tires.
EDIT: Forgot if I wanted to do 5mm spacer i'd need extended studs..sigh
#23
Yea I was afraid of that. I know they don't have the best reputation on the track but i'm tired of swapping rotors! haha I miss my bbk but I want to keep the stock wheels and not roll the fenders while running the largest tire I can. I'm asking too much haha. Gotta compromise somewhere.
I'm at -1.9 camber in the front with a 225 on the stock wheel and I'm not rubbing at all on the track or at autox. Adding another degree of negative camber and 5mm spacers should cancel eachother out to an extent, but that's too many variables to make a safe assumption.
#24
Snail, did you have to modify the heat shield? I have brake ducting through mine so I need to keep that in mind!
#28
Ive been looking at this exact kit specifically to curb my brake consumption costs at the track. I know the dynalite caliper makes a poor front brake (many other S2K wilwood kits use the dynalite), but this kit uses the superlite which is fantastic and is used extensively by corvette and mustang guys in road racing and innumerable other race cars. I know their calipers don't use dust boots (few racing calipers do), and they require safety wire retainers on the rotor to hat mating (this is a good thing in my mind), but these are just the trade-off for getting rotors that last and thicker, cheaper pads.
mlam81
02-09-2011 01:19 PM
esstwothousand
12-25-2009 05:00 PM
