Alternator Removal -> Spark -> Dead Car
- As the title says, I swapped my alternator today and I stupidly forgot to disconnect the battery ground terminal.
- I got an arc/spark and then disconnected the alteratior terminal. - Installed everything and now the car is dead. No Lights. - There is still continuity between the alternator and battery. - Battery reads 11v and change - But when I turn the key... Nothing no lights. Absolutely nothing. - I plan on checking all the fuses. - What else could I check? |
11 volts is too low. Should be in the high 12’s
- Found problem. Blown 100 A fuse.
