Bypassing imobiliser to fit F20c into AE86
Hey there guys and girls.
I'm in the process of buying an AE86 that it running an F20c on VEMS EMS. I am looking into changing the management to the stock honda item.
After copious amounts of research I gather that the S2000 is fitted with a transponder in the key and such when it is put into the ignition barrell send s signal to the ECU through the immobiliser reciever unit.
My question is, can I bypass this system?
My basic requirements are to get the car running under the stock honda management so that I no longer have to worry about cold starting and fueling.
I can imagine that one solution would be to utilise the whole system, taking the transponder out of the key and pushing it all up under the dash. So, the Honda ECU "thinks" the right key is being used. To be honest, I'm not keen on this idea as it gives me excess wiring under the dash.
I know it can be done because it HAS been done.
Thanks for reading.
Regards,
Ben
Thanks for reading.
Regards,
Ben
AH!
First bit of good news I've heard all week.
Is this 100%?
I'm presuming there is a slightly different map on the ecu too? Maybe for the higher octanbe fuel they use?
Regards,
Ben
Is this 100%?
Regards,
Ben
Originally Posted by Stealth_SUX_,Mar 25 2009, 10:01 AM
The bad part is that there ecu has speed limitor built in about 115mph or so..
