can this be done
Old Jun 1, 2008 | 03:05 AM
oo7ml's Avatar
Default can this be done
My immobiliser fob is nearly worn out (as seen in the pic below). I think all MY00's came with a standard alarm but were then called back to have an immobiliser fitted so the original alarm fob is of no use because it only controls the alarm and not the immobiliser
I have the original Honda alarm fob (as seen in the pic below) and i was wondering would it be possible to program the original alarm fob to control everything instead of replacing the immobiliser fob...
thanks in advance
Old Jun 1, 2008 | 05:20 AM
HARDtoTOP's Avatar
I am no expert, but that fob on the left looks like someone put in a cheap aftermarket alarm, not anything Honda did.
Old Jun 1, 2008 | 10:54 PM
oo7ml's Avatar
I' m nearly sure Honda put that as alarm into every car
Old Jun 2, 2008 | 07:31 AM
vspc2nr's Avatar
nope, thats aftermarket. like an old clifford.
Old Jun 2, 2008 | 09:25 AM
Stealth_SUX_'s Avatar
yep aftermarket
And to answer ur question though yes you can.. kinda complicated though.. weve done it before to other cars... Basically you have to open your aftermarket remote and hardwire the remote for power to the vehical (make sure you have the right voltage going to it though) then use the factory arm and disarm wires, tie them into the remote so when you lock through ur factory remote it will be like hitting lock on ur other remote too...
Im sure there might be an better way but this was quick and easy for us.
Old Jun 2, 2008 | 10:12 PM
NFRs2000NYC's Avatar
That is a dealer installed alarm, and has absolutely nothing to do with Honda. It's most likely a DEI alarm, so you would just need a DEI remote. Other than that, I can't really help.
PM Jackson (RevHi)....he has a lot of experience with alarms, and should be able to help you a little more.
Old Jun 2, 2008 | 10:27 PM
revhi's Avatar
Give me the number off the back of that remote. It should be something like "EZSDEI***."
Old Jun 3, 2008 | 12:18 AM
oo7ml's Avatar
Thanks a million for your help
The code on the back of the remotes read -
immobiliser remote:
EXEMPT
alarm remote:
ETS 300 220
G8D-453H-A
G130
779J
Do any of these codes make sense to you and thanks again
Old Jun 3, 2008 | 05:01 AM
revhi's Avatar
Thats not a DEI remote, Ill try to find out what it is for you. Do you have any manuals or info on the system? Is there a siren under the hood?
Old Jun 4, 2008 | 02:04 PM
MikeyCB's Avatar
Originally Posted by Stealth_SUX_,Jun 2 2008, 11:25 AM
yep aftermarket
That sounds like a pretty good solution to me actually!
Hardwiring in so the signal from the factory remote triggers the aftermarket remote to communicate the signal to the immobilizer box.
