S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Electronics (https://www.s2ki.com/forums/s2000-electronics-26/)
-   -   dome light (https://www.s2ki.com/forums/s2000-electronics-26/dome-light-1042855/)
DaMan22 Sep 5, 2013 10:18 AM
dome light
my dome light stopped working when i open and close the doors... the lights at the top work when i press the button...and the middle switch is set to doors (middle setting) what do you guys think it could be
Jorden Sep 5, 2013 11:23 AM
Hello there,
To me it kind of sounds like your door button switches might be sticky causing them to say down when the door is open. I hope this helps!
You can try this to see:
With a door open and the dome light switch set the middle position. Push down on the rubber boot on the door sill. When you push down on this the light should go off. but if its sticky pushing it might unstick it.
© 2026 MH Sub I, LLC dba Internet Brands
