How do you change the signal lights in a 1995 Chevy S10?
im not sure on the 95 model about the front, but the rear signal lights should be the same bulb as your brake lights ( it just has two fillaments). you need to open your tail gate and just on the side (where the tail gate normally covers) there should be two screws, remove these screws and change the lamps. and it goes back together the same way it came apart ( just reverse the proccess
