Momentary Switch for AP2 V2 Center Console?
I currently own a 2004 S2000 that is my project car. I am looking at moving the clutch safety switch off of the pedal and running it to a different switch inside the car, so that I don't have to depress my aftermarket clutch when starting the car. I know the 06+ AP2 V2 center console has a third button on it, where they moved the defroster off of the dash and replaced it with a traction control button. So, my thinking is that I'd like to replace my 2004 center console with a 2006+ center console and utilize the third button to replace my clutch safety switch, and as a bonus I much prefer the satin black to the silver AP2 V1 center console. Does anyone know if there is another button in the Honda parts bin that fits in the same location as the AP2 V2 defroster button and acts as a momentary switch?
https://cimg4.ibsrv.net/gimg/www.s2k...dba9df50a0.jpg |
I believe that switch is momentary anyway. The rear defroster is on a timer that is managed separate from the switch so the switch just gives the command. You would need to review the wire diagrams to determine which contacts on the switch close when it is pressed but that should not be too difficult.
FYI, I ended up wiring my VSA (traction control) button on the dash in parallel with the clutch interlock switch. That allowed me to use it as a clutch bypass while retaining the clutch interlock function as well. |
Originally Posted by jwzimm
(Post 24613242)
FYI, I ended up wiring my VSA (traction control) button on the dash in parallel with the clutch interlock switch. That allowed me to use it as a clutch bypass while retaining the clutch interlock function as well. It's funny you should mention the VSA OFF switch, as I was playing with mine in my TL today noticing that it is a momentary switch, and I saw that it looks like the VSA OFF switch from an 06-11 Ridgeline might be the same form factor as the AP2 V2 defroster button. So, it looks like I might have a couple options for buttons/switches. Thanks for the tip! |
The defroster button in the console is momentary. I put an MY06 button section and cup holder set into my MY04 console. The defroster button still has the defroster icon on the top but it's now my garage door opener. I took the circuit board out of my garage door opener, wired the defroster switch in parallel to the control button on the circuit board, mounted a battery to it and mounted the entire assembly under the button.
https://cimg7.ibsrv.net/gimg/www.s2k...179254a93f.jpg |
Originally Posted by hecash
(Post 24613315)
