Need Help with Pioneer Radio Problem
Well it all started about a month ago. For some reason, it seems like the number 3 in button in the radio preset option keeps on getting stuck. The radio out of the blue would just switch to that station and get stuck there. When I have it in another mode which doesn't show the preset radio stations, it would switch to that. The volume keeps on working during this, but everything else just freezes. Then I would wait a day and then it would partially start working again until it something triggers it to get stuck on that button. The radio works quality works fine. I was wondering what you guys thought. Do I need a new radio. If so, I wouldn't mind since i found out later with this radio that it doesn't play mp3's. One more thing, I need an aux input. I purchased the device from pioneer for this radio so I could play the sound on my tv. Is this peice interchangeable.
Thanks |
Depending on what exact piece you got from pioneer for you tv to play sound, if its just an fm modulator than yes. if its a changer port-aux piece it should still work.
on the other question for the buttons on the radio... i had a 9400 a couple years ago and it also developed some phantom problems with the face. i had pioneer service it, it cost me $100 and got it back from them the same way i sent it to them. they didnt fix it. seeing as its an older radio already i would suggest picking up a new radio. you can get a nice new radio that will play mp3's and have an aux input. i have a clarion dxz555mp that i sell in my store at 169.99, so if you look around i would think you should be able to find a good unit that would fit all your needs for under $200. hope this helps Erik, Sounds Car Audio |
