Passenger side window will not open!
The car is a 2002 s2000! silver! Love this car! But there is a slight problem.
The window will not go back up from the drivers side control, nor the passenger side control, but I can hear a switch clicking when push down on the "roof" switch. I can assume that power is going to the window, but there is no power to the relay switch. What should be the next step in trying to take care of this problem?? |
Check the drivers side for the passenger window "lock," make sure it is not on. If that doesnt solve it then take one the door panel and look for the problem, either regulator or track issue.
It was the window lock!! I'm so newb..
Hello ,
I had the same problem with my passenger window. It was stuck halfway. I could also hear the actuator working. I had to do this alone, so I wedged a piece a paper in the control button in the passenger door so it would be rolling the window up, The i grabbed the window and jerked it up , took 3 tries and finally released and rolled up. Been working fine ever since I did that. Not saying this will work every time but, worth a try. Good Luck Awesome , just seen your additional post. Glad to see it's working. Wasn't that easy in my case. :) |
Good to see folk falling for this on your side of the pond :D We usually drag it out for longer :rofl:
