Por favor senor... need help in oil-water sensor
Another favor....
Trying to connect an oil sensor and water temp sensor to an aftermarket digital dash, Do you know what is the ECU pin # of the oil sensor and the water temp sensor? The output wire from the ecu to the gauge. Is there an output wire from the s2000 ecu for these sensorS? Thanks again... |
I don't believe the S2000 ECU provides that info...you will need sensors to get it. I am 95% sure.
I thought there is wire in the S2000 ecu I can tap to go to the dash. |
