Powerlocks not working correctly?
After installing dynamat on both my doors, I am having an issue with the power locks. When using the remote when you hit the lock button, you hear nothing nor does anything happen, when you hit the unlock you hear a noise but nothing happens. The passenger door I can lock and unlock freely. The driver side how ever, I can not get it to lock or unlock manually. The only way I can get it to lock or unlock manually is if I pull on the door lever slightly (like im trying to open the door from the inside), and then I can do it manually.
I have a feeling the issue is with the drivers door somewere as the passenger door I can do everything manually. Does anyone know what I should try and look for? The dynamat isnt covering anything regarding the locks. Later today I am going to take off the passenger door to compare. |
when you pull the lever slightly, does the remote work at that point?
The lock doesn't work with the door open.
Sent using free Tapatalk - Android FTW |
Not sure what you're replying to, but notice he said "The only way I can get it to lock or unlock manually is if I pull on the door lever slightly (like im trying to open the door from the inside), and then I can do it manually." So I was asking if in the same situation that he gets the lock to work manually, if it would work with the remote. |
| All times are GMT -8. The time now is 02:45 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
