Simple Question
Old Apr 29, 2005 | 07:26 AM
alks2k's Avatar
Default Simple Question
I need to remove the factory radio so that I can connect my ipod cable. I also want to run the cable to the glovebox. I tried the search function - but frankly don't have the time (I'm at work) to go through 60 pages of search results.
If someone knows or has done this can you point me in the right direction to some pics and instructions.
Thanks - AK
Old Apr 29, 2005 | 09:06 AM
Ro_Ja Boy's Avatar
To remove factory radio:
Get a flathead screwdriver or knife and wrap it in electrical tape to prevent scratching. Pop the radio door assembly out by putting the screwdriver in between the vents right above the radio and the dash. I believe there is four clips. Then, unscrew the 4 screws holding the cd player in place. There will be an antenna connected and a pigtail. Take them both out. Voila. BTW...you might want to put a rag over the shift knob and shift knob trim to prevent scratching.
Ryan
Old Apr 29, 2005 | 09:37 AM
PJK3's Avatar
for wiring.... the how to is stickied at the top of the electronics forum. ( darkknight1999's 'How-To' threads, S2000 wiring, ...)
here's the link that you need... ignore the parts that don't apply to your needs.
https://www.s2ki.com/forums/index.php?showtopic=248785
edit: here's another thread that shows a bit more wiring as well... http://forums.s2ki.com/forums/index.php?showtopic=155135
TProuty
Jan 26, 2009 10:58 AM
tks2000
Jul 9, 2007 08:46 AM
Blk Prl
Apr 9, 2007 12:12 PM
rikhemi
Jan 26, 2005 06:58 AM
lucid
Apr 1, 2002 01:27 PM
