Weird..Revs drop every few secs with sub+amp [VID]
Is it a bad idea to connect the amp to the system without the sub connected?
..because I did it, and I got the same problem. The only wires in were power, ground and remote. The amp would hardly be drawing anything in this state, right?
Originally Posted by DFWs2k,Dec 23 2010, 11:44 PM
not amp, per se, this happens when you are drawing more power than your alternator/power can provide without pulling from other areas, if it bothers you, add another battery and a higher output alternator
Originally Posted by TestMonkey,Dec 28 2010, 08:47 PM
My problem wasnt as bad as this but instead of a bigger battery/ Alternator. Put a capacitor or maybe 2 in and it shoudl fix your problem. I got a capacitor for $15 at Frys and that solved my problem. The following are things I have connected to my battery. Radar detector, GPS, speaker amp, subwoofer and subwoofer amp, and sometimes charge my phone at the same time. The capacitor fixed the problem easy.
ETA: In response to the OP's problem, it's most likely a bad ground. The old amp might not have pulled enough current draw to make the lights flicker/engine stumble. Improve your ground and look into upgrading your battery.
Originally Posted by Neutered Sputniks,Dec 28 2010, 09:44 PM
No. The correct response is not "Add a capacitor". The correct action is what DFW did: "Upgrade your alternator and/or battery".
Originally Posted by TestMonkey,Dec 29 2010, 03:02 PM
Or simply add a capacitor and save your money.
Besides, any quality Cap is going to run close to what an upgraded battery will run ($75 compared to $100)
Thus, the correct response remains: upgrade your battery and/or alternator.
Originally Posted by Neutered Sputniks,Dec 29 2010, 04:57 PM
No. Capacitors are bandaids that don't really work. You're still way overstressing your electrical system and sooner, rather than later, you will have to replace your battery anyway.
but seriously i got my capacitor for $15. cheap bandaid.
Originally Posted by TestMonkey,Dec 29 2010, 06:47 PM
Its not about quality its about quantity JK
But, hey, not like I'd know anything about that.
