Wiring Diagram For the Factory KeylessEntry Module
Hey I Really need your help trying to find the page on the Service Wiring Honda Book, I downloaded that .PDF Service Manual but they didn't scan those las pages where it talks about the SECURITY/KEYLESS/POWER DOOR LOCKS, if you have the manual and you can get access to a scanner or if you can type the wiring on that module I'll appreciate it so much , I'll even pay for it if you'all want me too.....thanks :bow:
D. |
Bump for Help....
www.helminc.com buy the electric wiring manual
See if this has anything in it for you.
https://www.s2ki.com/forums/index.ph...mg=241361&md=1 https://www.s2ki.com/forums/index.ph...mg=241360&md=1 |
which wires are you looking for?
Hey guys I apreciate all that Help, I'm looking the wiring diagram that goes to the KEYLESS ENTRY MODULE, like which wire goes where on the Plug that goes to that module.....somebody I know cut al the wires from that plug to "Install My Alarm" (yeah right)....He couldn't make the door locks work so I ended Up with out Keyless entry for now which it sucks....Thanks For you'alls time..
D. |
BTW now I know how to make them work but thats why I need that Diagram Thanks....
D. |
Dude, theres like thousands of s2000 owners on here...why dont you just ask for the wiring by pin for the keyless harness.
Someone could give you a list of the colors in order. BTW, you can get keyless at the module, there are two open slots in between a red/white and yellow/black. The slot closest to the red/white is lock, the other unlock...negative trigger. Just have to find some terminated ends to plug into the slots that are the same as the stock ones, or solder directly to the module and run the wires through the open slots. |
for the 2002 model, it is a 5 wire locking system so you would need a relay in order to get your locks to work.
Why do noob's feel the need to bring old thread back from the dead... :rolleyes:
