Aem back to stock and wont start
Old 04-24-2014, 11:28 AM
s2000Junky's Avatar
If it starts with starting fluid, then that tells me it’s not getting fuel and you are getting spark. Not getting fuel could be caused by several things. Seems like you would want to Start at the fuel pump, make sure its turning on/working and work towards the injectors. If you have fuel pressure at the rail, then it seems like the injectors are not being told to inject and that’s where to concentrate your efforts. From here, any well skilled mechanic should be able to deduct further and determine the cause of that. Something tells me its still involved with the immobilizer, or something in the harness got missed or damaged during the engine swap.
Good luck
Old 04-24-2014, 07:21 PM
odin360's Avatar
Originally Posted by s2000Junky
If it starts with starting fluid, then that tells me it’s not getting fuel and you are getting spark. Not getting fuel could be caused by several things. Seems like you would want to Start at the fuel pump, make sure its turning on/working and work towards the injectors. If you have fuel pressure at the rail, then it seems like the injectors are not being told to inject and that’s where to concentrate your efforts. From here, any well skilled mechanic should be able to deduct further and determine the cause of that. Something tells me its still involved with the immobilizer, or something in the harness got missed or damaged during the engine swap. Good luck
I agree 100% with you. Immobilizer is excluded. So do you know of any sensor beside crankshaft sensor or camshafts that would cut me out?
Old 04-25-2014, 07:49 AM
Stratocaster's Avatar
Both of these should throw a code if they are the issue. So it turns over, just will not fire? Check all the ground connections to the motor. The ground connection on the rear of the head is enough to cause this issue. It is behind the head, almost down to the head/block seam between the head and firewall.
jpetch05
02-04-2013 06:34 PM
s2kseven
09-20-2012 01:56 PM
learnerspermit
09-14-2012 04:08 PM
news2kroller
04-21-2008 09:56 PM
Spoolin
06-09-2006 12:30 PM
Quick Reply: Aem back to stock and wont start
