AEM Series 2 - Temp Coolant Cal Voltage Scale Change
I'm new to tuning in general, and was reviewing the current tune on my aem v2 on a '05 because of lean-idle situation. I've put a bandaid on the issue by increasing the hotter end on the Start Decay table, but when reading through the threads here i found the thread that provides corrected temperature calibration points: https://www.s2ki.com/forums/s2000-un...ations-184552/
But the points provided in the thread are out to hundredths of a volt, and my current display only allows adjustments every two-tenths. Is there a way to change the calibration scale to make it easy to load the correct temp data? Aside from the warm-up tables, are there any others i need to look out for when I change the temperature range? |
you can't change the breakpoints of the temp calibration table.
so you'll have to interpolate the values to match the aem table scales. not sure if the other user's data is accurate tho either... |
Originally Posted by AlpineFD
(Post 24594437)
