AEM Tuner won't connect to ECU Windows 10
Hi,
I have upgraded my laptop to Windows 10 and now AEMTuner 3.2 doesn't seem to find my AEM EMS when I connect it via USB.
Has anyone had the same issue with windows 10? Did you manage to resolve it?
It looks like it needs a new USB driver but I can't see anything on AEM website
It worked fine under windows 7
This is what the screen says ....
Screen Shot
Thanks
Robert
Screen Shot
Thanks
Robert
I can finally update my laptop after almost 2 years. Thank you! I had the original windows 8 installed without any updates. Once you update the very first time it killed my aem connection. THANK YOU!
Has anyone else had any issues with this?
Followed the instructions and switched off power management on the usb port through reg edit. Unfortunately this does not seem to have done anything to solve my connection issue.
I've tried in all states with car off, ign on and car running. Noe of these seem wake up the system and allow connection.
Yes,
Double checked entry name, also managed to turn off the power management without reg edit when just right click and properties of the driver. It had a tab "Power Management".
Tried that way and the reg edit way. Neither worked. Tried different USB ports...still no luck.
Yes,
i had the same issues ..what worked for me is right when you Click on connect ecu and system searches for ecu,remove USB cable and reconnect instantly you will see the connection to ecu complete and tables will open. I have to do this everytime For my ecu to be reconized. Hope this helps
plug in, hit connect, wait for the pop up that says trying to connect, then unplug and plug back in
there is some USB performance setting in win10 you can disable to fix it i believe but unplugging it works
For those of you having connections issues. It is extremely important that you do not have a low battery in your car and all your grounds are good. You will have all kinds of issues if your battery is not up to snuff. Additionally, reloading the firmware on your AEM has fixed the issue for many users including myself. I had to redo it I think 3 times before it fixed my connections issues. I haven't had any issues since.
