Antifreeze leak
Antifreeze leak coming from the red area.
What is the silver pipe part called? Or, the part number for silver pipe? https://cimg8.ibsrv.net/gimg/www.s2k...1970221882.jpg |
If it the hose itself, God have mercy on you :) Ok not that bad maybe, but the other end is connected to the water outlet, below where the upper radiator hose connects and is a BIATCH to get to. I did mine wihile doing the clutch with the motor lowered and tilted and it was still a PITA. I will get you the parts info here in a sec
Got to Majestic Honda to look up the parts. Then search for Water Valve. That will get you the listing of all the parts you see there and you can pick the one you need.
Water Valve for 2001 Honda S2000 | Majestic Honda Automotive Parts That is for an AP1 so update it if yours is an AP2 Are you 100% sure it is coming from that line? Can you see coolant on the line or hose? Or is it just coming from that general area? Mine was leaking from the water outlet itself, and it was the oring. It is a pain to do so if you have to deal with that I would consider doing the upper radiator hose while in there. If it is coming from the water outlet, it will be under the water pump section Water Pump for 2001 Honda S2000 | Majestic Honda Automotive Parts |
Originally Posted by engifineer
(Post 25026807)
I opened the oval shape up a little (with some pliers) without confirming if that was how the silver pipe was intentionally made. When I put my finger under the area where the hose connects to the silver pipe I saw antifreeze on my finger. I collapsed the silver pipe back to an oval shape again and reattached the hose. I hope that resolves the issue. |
Really appreciate the part number for the silver pipe so that I can determine if the
part is intentionally supposed to be tapered to an oval shape. Thanks in advance. |
Originally Posted by WidWidi
(Post 25026855)
I had taken off the hose (around the red outlined area) on a previous occasion and noticed that the silver pipe went from a "O" shape and tapered to an oval shape.
| All times are GMT -8. The time now is 01:08 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
