checking air fuel ratio from data logging on flashpro, how accurate?
1 Attachment(s)
hey guys, i decided to datalog my s2000 today just to see how everything looks. im actually pretty new at this but i noticed that my air fuel ratio during WOT was around 10.14 and 12.25 (corrected)
I am confused what the difference between the two are. i did a bit of searching but didnt have any luck, other than they both will be different from each other. my current set up 2006 s2000 sos stage 2 supercharger with 9psi pulley rc650cc injectors berk 63mm high flow cat divert-er valve is dispensing to atmosphere stock cluck and flywheel 91 octane tuned from a very reputable shop in so cal here is a screenshot of what i am talking about. throttle plate is 100% Attachment 189269 shed some knowledge on me guys, i dont want to blow a motor lol also temp outside was 93 and i smelled my dipstick and no smell of gas! |
Look at the AF.Corr value on your sensor list on the left. It's showing 12.25:1. It's pretty accurate to within a couple 1/10's. However, as you go richer, the reading decreases in accuracy. For WOT, you want to look at this corrected value.
Data log a WOT you're run to redline, and PM me. I will check it for you if you're worried. |
Originally Posted by 06Estukay
(Post 23138585)
Data log a WOT you're run to redline, and PM me. I will check it for you if you're worried. Thank you so much. I had a feeling this was the case but I needed someone else to verify. I just ran a 3rd gear wot and my afcorected ratios are looking good. are the air fuel ratios off because of the o2 sensor on the 06 doesnt actually read correct unlike if i get an aftermarket bosch one? |
No problem.
Who better to explain it, then Hondata themselves. Here ya go: http://www.hondata.com/help/flashpro...correction.htm |
