S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Engine Management (https://www.s2ki.com/forums/s2000-engine-management-231/)
-   -   disable secondary o2 sensor in flashpro (https://www.s2ki.com/forums/s2000-engine-management-231/disable-secondary-o2-sensor-flashpro-848631/)
Swiftoy Feb 23, 2011 02:11 PM
Okay, I loaded flashpro with the toda calibration and after fooling aroung with the different menus in flashpro I couldnt figure out how to go about disabling the secondary O2. I could use some help thanks.
Swiftoy Feb 23, 2011 03:46 PM
Wow after 19 views I figured someone chime in.
scareyourpassenger Feb 24, 2011 03:55 AM
Did you check the help file?
xredjar Feb 24, 2011 08:41 AM
Not sure what the problem is...
When you open FP, load a calibration
select the Calibration tab
click on Closed Loop on the left side
at the top there is a checkbox for Secondary oxygen sensor enabled.....uncheck it
hope this helps
Swiftoy Feb 24, 2011 11:49 AM
I actually found what I was looking for thanks. Now I have the code for the primary that just came up I know there is a tsb for it looks like new primary sensor.
SlowTeg Mar 1, 2011 06:30 PM
If the secondary o2 sensor is disabled, can it be removed/left unplugged completely, or does it still need to be plugged in (or it'll throw a code)?
Swiftoy Mar 2, 2011 08:59 AM
Why would you want to completely remove it if it can be disabled. Just seems like a lot of extra work to remove the sensor.
SlowTeg Mar 2, 2011 06:01 PM
You have to be kidding, right? Work to remove a sensor? You mean unscrew it and unplug it from the harness? lol You can easily use a plug for the hole. :suspect:
I guess I'd have to ask why you'd even WANT to leave it connected if you're disabling it in the first place..? To add, for those fabbing up a straight pipe, it means one less bung you have to weld in for the secondary o2.
Hopefully someone can now chime in whether the o2 sensor can be removed entirely/unplugged w/o throwing a code.
psychoazn Mar 5, 2011 01:34 AM
Bump, I'd like an answer too :)
Swiftoy Mar 7, 2011 05:38 AM
Maybe you enjoy getting under a car all the time or maybe you have access to a lift I don't! It's very easy to remove no doubt but is Pretty F*****g simple to just disable with the software uncheck the box and your done and leave well enough alone. To each there own.
© 2026 MH Sub I, LLC dba Internet Brands
