Flash pro
Is it just as good as AEM ecu or even better?
Not sure what model year you have but it can only be used for 06 - 09 ap2. 2nd of all, the flash pro is not an ECU; you use it to "flash" or program the stock ECU. The AEM ECU is a totally separate ECU from stock, but you will have more options to control/program. Most people use the AEM ECU or another standalone when they turbocharge a car because they cannot use he stock ECU anymore. U can still get away with using the stock ECU when u supercharge but only at low boost.
Hope that was helpful. |
Yea I was referring to 06 and up. Thanks
Originally Posted by gnehc1
(Post 21565771)
Hope that was helpful. If you have an 06+ s2000 and use anything but flashpro, you are wasting money and ease of operation. Sent using free Tapatalk - Android FTW |
Originally Posted by DFWs2k
(Post 21565833)
No that's not helpful because it is not true at all, in regards to 06+ s2000s.
If you have an 06+ s2000 and use anything but flashpro, you are wasting money and ease of operation. Sent using free Tapatalk - Android FTW Unless you have plans for nitrous, or something really exotic, li,ke transplaniting a DBW F22 into a different vehicle, then FlashPro is the best way to go. |
| All times are GMT -8. The time now is 03:31 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
