GReddy Emanage Ultimate - Harness power issue
Hey all,
I picked up a GReddy Emanage Ultimate and harness from the forums, but am having a couple issues getting it to work. I have a 2005 S2000, and the Emanage/Harness is for an AP1 but the harness has been modified for an AP2. I installed it, and turned the key to the 'On' position, but neither the 'Active' light nor he 'Communicate' light on the Emanage came on. I tried a couple things, but finally just took the harness of the car and the factory ECU, spliced into the Power and Ground, and directly connected the Emanage to 12V Aux and ground. I turned the key 'On' and both Emangae lights came on solid.
As I've never used one of these before, I didn't know what to expect from the power other than it to start right up. I assume that the harness is faulty if it can't pull power from the factory ECU?
I haven't started it yet. The fuel system is disassembled waiting for new injector seals to come later this week. Just trying to get ahead on the setup for the emanage.
I couldn't get my windows 7 laptop to recognize the software so I've picked up a cheap XP laptop to check shortly.
Well, i'm probably an idiot. I've got the fuel pump fuse out because i've been working on the fuel system. If the fuse is removed, it looks like no power is put to the ECU? I'll have to confirm later this week. I didn't think having a fuse out for something like the fuel pump would result in no power.
Confirmed: I'm an idiot. Pulling the fuel pump fuse will completely disable power from the ECU, so the Emanage wasn't getting anything.
